Einleitung
Use this guide to replace your battery in your HP Pavilion laptop.
Note: This guide is written for the HP Pavilion x360 14-ba253cl model.
Still under warranty? Contact HP to learn your warranty status, receive a repair under warranty if eligible, or for further warranty information.
This procedure requires removing the battery to disconnect it. Use care to avoid bending, twisting, or puncturing it—a charged lithium-ion battery can be very dangerous if accidentally punctured. If your battery looks puffy or swollen, take extra precautions.
Don't continue to use a damaged battery, as doing so is a potential safety hazard. If in doubt, replace it with a new battery.
Was du brauchst
Use the Jimmy to remove the footpads located at the bottom of the laptop.
Remove three 4.0mm Phillips #0 screws from the top of the cover.
Remove two 6.0mm Phillips #0 screws underneath each of the back footpads.
Remove one 4.mm Phillips #0 screw beneath the divot.
Turn the computer onto its base, with the computer open and the keys facing upward.
Raise the keyboard slightly to gain access to the touch pad and keyboard cables.
Using a spudger, lift up the plastic locks that connect the ribbon cable to the system board.
Use the blue plastic tab on the ribbon cable to pull it out from the system board.
Remove the keyboard from the laptop.
Remove six 3mm Phillips #00 screws around the perimeter of the battery.
Carefully lift the battery starting from the lower right corner and disconnect it from the system board.
5 weitere Personen haben diese Anleitung absolviert.
