Zum Hauptinhalt wechseln
HP Pavilion x360 m3-u101dx Display Replacement
Was du brauchst
  1. HP Pavilion x360 m3-u101dx Display Replacement, Keyboard Panel: Schritt 1, Bild 1 von 1
    • Flip the laptop over so that the bottom of the laptop is facing up.
  2. HP Pavilion x360 m3-u101dx Display Replacement: Schritt 2, Bild 1 von 1
    • Remove five 1.4mm Phillips #1 screws from the bottom of the laptop.
  3. HP Pavilion x360 m3-u101dx Display Replacement: Schritt 3, Bild 1 von 3 HP Pavilion x360 m3-u101dx Display Replacement: Schritt 3, Bild 2 von 3 HP Pavilion x360 m3-u101dx Display Replacement: Schritt 3, Bild 3 von 3
    • Remove the rubber grip using a plastic opening tool.
    • Remove five 1.7mm Phillips #1 screws.
  4. HP Pavilion x360 m3-u101dx Display Replacement: Schritt 4, Bild 1 von 3 HP Pavilion x360 m3-u101dx Display Replacement: Schritt 4, Bild 2 von 3 HP Pavilion x360 m3-u101dx Display Replacement: Schritt 4, Bild 3 von 3
    • Lift open the laptop screen and flip it around so that the keyboard is facing up.
    • Insert a plastic opening tool into one of the corners to create a gap between the bottom panel and the keyboard panel.
    • Guide the plastic opening tool around the perimeter of the panel to detach all the clips that are supporting it in place.
    • Do not pull the panel off by one corner as it can cause damage to the plastic.
    • Detach the keyboard panel from the frame.
    • There are two ribbon cables attached to the keyboard and trackpad so do not pull the keyboard panel away until you disconnect these ribbons in the next step.
  5. HP Pavilion x360 m3-u101dx Display Replacement: Schritt 5, Bild 1 von 3 HP Pavilion x360 m3-u101dx Display Replacement: Schritt 5, Bild 2 von 3 HP Pavilion x360 m3-u101dx Display Replacement: Schritt 5, Bild 3 von 3
    • Remove the two ribbon cables connected to the inside of the laptop by using a finger to lift up on the latches.
    • Remove the keyboard panel from the rest of the laptop.
  6. HP Pavilion x360 m3-u101dx Display Replacement, Display: Schritt 6, Bild 1 von 3 HP Pavilion x360 m3-u101dx Display Replacement, Display: Schritt 6, Bild 2 von 3 HP Pavilion x360 m3-u101dx Display Replacement, Display: Schritt 6, Bild 3 von 3
    • Use the iFixit opening tool to flip the cable tab up, located at the top right corner of the motherboard.
    • Detach the display power cable from the motherboard.
    • Once the cable is loose, remove it from the cable case.
  7. HP Pavilion x360 m3-u101dx Display Replacement: Schritt 7, Bild 1 von 3 HP Pavilion x360 m3-u101dx Display Replacement: Schritt 7, Bild 2 von 3 HP Pavilion x360 m3-u101dx Display Replacement: Schritt 7, Bild 3 von 3
    • Use the suction handle and attach it to the bottom corner of the display.
    • Slide the iFixit opening tool around the display to loosen the clips attaching it to the case.
    • If you have difficulty removing the display, move the suction handle to the other corners.
    • When the display is removed from the case, pull the power cable from the bottom case through the hinge.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
York University, Team S8-G1, Turner Winter 2020 Mitglied von York University, Team S8-G1, Turner Winter 2020
YORK-TURNER-W20S8G1
5 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 9
Insgesamt: 429
