Zum Hauptinhalt wechseln
HP Pavilion x360 m3-u103dx Fan Replacement
Was du brauchst
  1. HP Pavilion x360 m3-u103dx Fan Replacement, Fan: Schritt 1, Bild 1 von 1
    • Power off device.
    • Flip laptop over.
  2. HP Pavilion x360 m3-u103dx Fan Replacement: Schritt 2, Bild 1 von 2 HP Pavilion x360 m3-u103dx Fan Replacement: Schritt 2, Bild 2 von 2
    • Remove the rubber foot with a Metal spudger
    • Remove 5 Phillip 2.4 x 5.7mm screws using a PH0 Phillips head screwdriver.
    • Remove 5 Phillips 2.8 x 5.0mm screws using a PH0 Phillips head screwdriver.
  3. HP Pavilion x360 m3-u103dx Fan Replacement: Schritt 3, Bild 1 von 3 HP Pavilion x360 m3-u103dx Fan Replacement: Schritt 3, Bild 2 von 3 HP Pavilion x360 m3-u103dx Fan Replacement: Schritt 3, Bild 3 von 3
    • Open computer and pry open keyboard panel using the Metal Spudger. Apply little pressure then increase until keyboard pops away from motherboard.
    • Gently lift keyboard on the mouse pad side. Remove three connected ribbon wires connecting keyboard to frame by gently disconnecting them from the motherboard.
  4. HP Pavilion x360 m3-u103dx Fan Replacement: Schritt 4, Bild 1 von 1
    • Remove eleven 2.0 x 4.6mm screws using the Phillips 00 Screwdriver
  5. HP Pavilion x360 m3-u103dx Fan Replacement: Schritt 5, Bild 1 von 3 HP Pavilion x360 m3-u103dx Fan Replacement: Schritt 5, Bild 2 von 3 HP Pavilion x360 m3-u103dx Fan Replacement: Schritt 5, Bild 3 von 3
    • Remove the motherboard gently from the base of the laptop.
    • Disconnect the fastened cables from the motherboard by carefully pushing the cable's plastic edges using the metal Spudger.
  6. HP Pavilion x360 m3-u103dx Fan Replacement: Schritt 6, Bild 1 von 2 HP Pavilion x360 m3-u103dx Fan Replacement: Schritt 6, Bild 2 von 2
    • Using the Phillips 00 Screw Driver. remove 4 screws from the heat sink.
    • Remove any adhesive tape. Detach the fan/heat sink.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 26
Insgesamt: 1,405
