Zum Hauptinhalt wechseln
HP ProBook 450 G4 Fan Replacement
Was du brauchst
  1. HP ProBook 450 G4 Fan Replacement, Hard Drive: Schritt 1, Bild 1 von 2 HP ProBook 450 G4 Fan Replacement, Hard Drive: Schritt 1, Bild 2 von 2
    • Power your laptop off.
    • Flip the laptop over.
    • Orient the laptop so the two vents on the bottom face upward and are further away from you.
  2. HP ProBook 450 G4 Fan Replacement: Schritt 2, Bild 1 von 3 HP ProBook 450 G4 Fan Replacement: Schritt 2, Bild 2 von 3 HP ProBook 450 G4 Fan Replacement: Schritt 2, Bild 3 von 3
    • Use the Phillips #0 screwdriver to remove the 6.8 mm screw that secures the vent panel to the laptop.
    • Use the spudger to separate the vent panel from the laptop.
    • Slide the vent panel off the backside of the laptop.
  3. HP ProBook 450 G4 Fan Replacement: Schritt 3, Bild 1 von 2 HP ProBook 450 G4 Fan Replacement: Schritt 3, Bild 2 von 2
    • Use the Phillips #0 screwdriver to remove the black 3.2mm screw that secures the hard drive to the left side of the laptop.
  4. HP ProBook 450 G4 Fan Replacement: Schritt 4, Bild 1 von 2 HP ProBook 450 G4 Fan Replacement: Schritt 4, Bild 2 von 2
    • Use the spudger to lift the left side of the hard drive up.
    • Pull the hard drive diagonally to the left to release the hard drive from the laptop.
  5. HP ProBook 450 G4 Fan Replacement, Keyboard: Schritt 5, Bild 1 von 3 HP ProBook 450 G4 Fan Replacement, Keyboard: Schritt 5, Bild 2 von 3 HP ProBook 450 G4 Fan Replacement, Keyboard: Schritt 5, Bild 3 von 3
    • Remove the 6.6mm T8 Torx screw located below where the hard drive used to be.
    • Remove the 6.6mm T8 Torx screw located below and to the left of the circular, silver and black fan.
  6. HP ProBook 450 G4 Fan Replacement: Schritt 6, Bild 1 von 3 HP ProBook 450 G4 Fan Replacement: Schritt 6, Bild 2 von 3 HP ProBook 450 G4 Fan Replacement: Schritt 6, Bild 3 von 3
    • Use the spudger to press down on the two black tabs that are underneath where the hard drive used to be.
    • Apply pressure to the black tabs until they release and pop out.
  7. HP ProBook 450 G4 Fan Replacement: Schritt 7, Bild 1 von 3 HP ProBook 450 G4 Fan Replacement: Schritt 7, Bild 2 von 3 HP ProBook 450 G4 Fan Replacement: Schritt 7, Bild 3 von 3
    • Orient the laptop so the keyboard is facing upwards and towards you.
    • Insert the spudger in between the edge of the keyboard and the computer frame.
    • Slide the spudger around the edge of the keyboard until the keyboard is loose.
    • Gently pull the keyboard away from the body of the laptop.
    • Do not pull the keyboard all the way off because there is still a connector cable underneath that needs to be disconnected.
  8. HP ProBook 450 G4 Fan Replacement: Schritt 8, Bild 1 von 2 HP ProBook 450 G4 Fan Replacement: Schritt 8, Bild 2 von 2
    • Use a spudger to gently lift up the black locking bar on the keyboard connector.
    • Slide the keyboard ribbon out of the connector.
    • Remove the keyboard.
    • To re-attach the keyboard ribbon, slide it into the connector and swing the locking bar down.
  9. HP ProBook 450 G4 Fan Replacement, Battery: Schritt 9, Bild 1 von 2 HP ProBook 450 G4 Fan Replacement, Battery: Schritt 9, Bild 2 von 2
    • Flip the laptop back over.
    • Remove the eight 6.8mm T8 Torx screws on the backside of the laptop.
  10. HP ProBook 450 G4 Fan Replacement: Schritt 10, Bild 1 von 2 HP ProBook 450 G4 Fan Replacement: Schritt 10, Bild 2 von 2
    • Use a Phillips #0 screwdriver to remove the three 6.6mm screws from the upper left corner of the laptop.
  11. HP ProBook 450 G4 Fan Replacement: Schritt 11, Bild 1 von 2 HP ProBook 450 G4 Fan Replacement: Schritt 11, Bild 2 von 2
    • Use the spudger to slide the disk drive out of the laptop.
    • Use the Phillips #0 screwdriver to remove the two 3.2mm screws that are underneath where the disk drive previously was.
  12. HP ProBook 450 G4 Fan Replacement: Schritt 12, Bild 1 von 3 HP ProBook 450 G4 Fan Replacement: Schritt 12, Bild 2 von 3 HP ProBook 450 G4 Fan Replacement: Schritt 12, Bild 3 von 3
    • Use a Phillips #0 screwdriver to remove the two 6.6mm screws.
  13. HP ProBook 450 G4 Fan Replacement: Schritt 13, Bild 1 von 2 HP ProBook 450 G4 Fan Replacement: Schritt 13, Bild 2 von 2
    • Flip the laptop back over so it is facing upwards.
    • Remove the six 6.6mm T8 Torx screws underneath where the keyboard used to be.
  14. HP ProBook 450 G4 Fan Replacement: Schritt 14, Bild 1 von 3 HP ProBook 450 G4 Fan Replacement: Schritt 14, Bild 2 von 3 HP ProBook 450 G4 Fan Replacement: Schritt 14, Bild 3 von 3
    • Use the spudger to disconnect the nine cable connectors that secure the top case of the laptop to the body of the laptop.
    • Be extra careful while disconnecting the cable connectors because they can tear easily.
  15. HP ProBook 450 G4 Fan Replacement: Schritt 15, Bild 1 von 2 HP ProBook 450 G4 Fan Replacement: Schritt 15, Bild 2 von 2
    • Insert the spudger in between the top case of the laptop and its outer frame.
    • Slide the spudger around the edge of the laptop until the top case comes off.
    • Remove the top case.
  16. HP ProBook 450 G4 Fan Replacement: Schritt 16, Bild 1 von 2 HP ProBook 450 G4 Fan Replacement: Schritt 16, Bild 2 von 2
    • Insert the opening tool underneath the left side of the battery to remove it from the laptop.
  17. HP ProBook 450 G4 Fan Replacement, Fan: Schritt 17, Bild 1 von 3 HP ProBook 450 G4 Fan Replacement, Fan: Schritt 17, Bild 2 von 3 HP ProBook 450 G4 Fan Replacement, Fan: Schritt 17, Bild 3 von 3
    • Use the spudger to disconnect the two cable connectors that secure the fan to the laptop.
  18. HP ProBook 450 G4 Fan Replacement: Schritt 18, Bild 1 von 1
    • Insert the spudger underneath the black wire that wraps over the top of the fan.
    • Use the spudger to pull the black wire away from the top of the fan.
  19. HP ProBook 450 G4 Fan Replacement: Schritt 19, Bild 1 von 2 HP ProBook 450 G4 Fan Replacement: Schritt 19, Bild 2 von 2
    • Use a TR9 Torx screwdriver to remove the 6.6mm black screw directly above the fan.
  20. HP ProBook 450 G4 Fan Replacement: Schritt 20, Bild 1 von 1
    • Insert the spudger under the right side of the fan.
    • Use the spudger to gently lift the fan from the laptop.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
Sebastian Dow
1.007 Reputation
6 Anleitungen geschrieben
Cal Poly, Team S1-G3, White Winter 2020 Mitglied von Cal Poly, Team S1-G3, White Winter 2020
CPSU-WHITE-W20S1G3
4 Mitglieder
18 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 27
Insgesamt: 2,699
