Zum Hauptinhalt wechseln
HP Spectre 13 4003dx x360 Motherboard Replacement
Was du brauchst
  1. HP Spectre 13 4003dx x360 Motherboard Replacement, Battery: Schritt 1, Bild 1 von 2 HP Spectre 13 4003dx x360 Motherboard Replacement, Battery: Schritt 1, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Magnetic Project Mat
    $19.95
    Kaufen
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Turn the computer upside down.
    • Use the T5 Torx Screwdriver to remove the eight 3.3 mm screws.
    • Make sure to use the magnetic project mat to help you keep track of the small screws.
  2. HP Spectre 13 4003dx x360 Motherboard Replacement: Schritt 2, Bild 1 von 2 HP Spectre 13 4003dx x360 Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Use an opening tool to pry up and loosen the back case from the laptop.
    • If the back case doesn't loosen easily, there may be screws hidden underneath the rubber feet. Carefully pry a foot up and remove any hidden screws.
    • Remove the back case.
  3. HP Spectre 13 4003dx x360 Motherboard Replacement: Schritt 3, Bild 1 von 2 HP Spectre 13 4003dx x360 Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Remove the four 2mm Phillips #00 screws securing the battery.
    • The screw locations are marked by small white arrows on the battery.
  4. HP Spectre 13 4003dx x360 Motherboard Replacement: Schritt 4, Bild 1 von 3 HP Spectre 13 4003dx x360 Motherboard Replacement: Schritt 4, Bild 2 von 3 HP Spectre 13 4003dx x360 Motherboard Replacement: Schritt 4, Bild 3 von 3
    • Peel off the adhesive on the left side of the battery holding the speaker wire down.
    • Move the battery slightly to gain access to the battery plug, located on the left edge of the battery.
    • Carefully unplug the battery by pulling the connector towards the battery.
    • Pull parallel to the battery, not straight up.
    • Remove the battery.
    • It is normal for your battery to flex and bend a bit where the wider section meets the narrower section.
  5. HP Spectre 13 4003dx x360 Motherboard Replacement, Motherboard: Schritt 5, Bild 1 von 3 HP Spectre 13 4003dx x360 Motherboard Replacement, Motherboard: Schritt 5, Bild 2 von 3 HP Spectre 13 4003dx x360 Motherboard Replacement, Motherboard: Schritt 5, Bild 3 von 3
    • Remove the two 2mm Phillips #00 screws from the fan.
    • Disconnect the fan from the motherboard.
  6. HP Spectre 13 4003dx x360 Motherboard Replacement: Schritt 6, Bild 1 von 3 HP Spectre 13 4003dx x360 Motherboard Replacement: Schritt 6, Bild 2 von 3 HP Spectre 13 4003dx x360 Motherboard Replacement: Schritt 6, Bild 3 von 3
    • Using a plastic opening tool, disconnect the antenna wires from the WiFi card.
    • Remove the single Phillips #00 screw from the WiFi card.
    • Slide the module up until it is completely removed.
  7. HP Spectre 13 4003dx x360 Motherboard Replacement: Schritt 7, Bild 1 von 2 HP Spectre 13 4003dx x360 Motherboard Replacement: Schritt 7, Bild 2 von 2
    • Use a plastic opening tool to flip up the retaining flap on the ribbon cable ZIF socket.
    • Pull the ribbon cable out of the ZIF connector.
  8. HP Spectre 13 4003dx x360 Motherboard Replacement: Schritt 8, Bild 1 von 1
    • Using two plastic opening tools, Disconnect the right speaker cable from the motherboard.
  9. HP Spectre 13 4003dx x360 Motherboard Replacement: Schritt 9, Bild 1 von 3 HP Spectre 13 4003dx x360 Motherboard Replacement: Schritt 9, Bild 2 von 3 HP Spectre 13 4003dx x360 Motherboard Replacement: Schritt 9, Bild 3 von 3
    • Identify the ZIF connector that connects the keyboard to the back light as shown in the image.
    • Using a plastic opening tool, lift the locking bar on the ZIF connector that connects the keyboard back light to the motherboard.
    • Gently pull the cable out.
  10. HP Spectre 13 4003dx x360 Motherboard Replacement: Schritt 10, Bild 1 von 3 HP Spectre 13 4003dx x360 Motherboard Replacement: Schritt 10, Bild 2 von 3 HP Spectre 13 4003dx x360 Motherboard Replacement: Schritt 10, Bild 3 von 3
    • Gently peel back the tape on the locking bar of the keyboard connector.
    • Using a plastic opening tool, pull up on the locking bar.
  11. HP Spectre 13 4003dx x360 Motherboard Replacement: Schritt 11, Bild 1 von 3 HP Spectre 13 4003dx x360 Motherboard Replacement: Schritt 11, Bild 2 von 3 HP Spectre 13 4003dx x360 Motherboard Replacement: Schritt 11, Bild 3 von 3
    • Identify the touch pad ZIF cable as shown in the image.
    • Using a plastic opening tool, Gently lift up the locking bar on the touch pad ZIF.
    • Gently slide the cable out.
  12. HP Spectre 13 4003dx x360 Motherboard Replacement: Schritt 12, Bild 1 von 2 HP Spectre 13 4003dx x360 Motherboard Replacement: Schritt 12, Bild 2 von 2
    • Using a plastic opening tool, Lift the locking bar on the card reader ZIF connector.
  13. HP Spectre 13 4003dx x360 Motherboard Replacement: Schritt 13, Bild 1 von 1
    • Using two plastic opening tools, Disconnect the left speaker cable.
  14. HP Spectre 13 4003dx x360 Motherboard Replacement: Schritt 14, Bild 1 von 1
    • Using two plastic opening tools, Unplug the power cable connector.
  15. HP Spectre 13 4003dx x360 Motherboard Replacement: Schritt 15, Bild 1 von 2 HP Spectre 13 4003dx x360 Motherboard Replacement: Schritt 15, Bild 2 von 2
    • Using a plastic opening tool, Lift the locking bar on the display connector.
    • Grip the black tape and pull up to unplug.
  16. HP Spectre 13 4003dx x360 Motherboard Replacement: Schritt 16, Bild 1 von 3 HP Spectre 13 4003dx x360 Motherboard Replacement: Schritt 16, Bild 2 von 3 HP Spectre 13 4003dx x360 Motherboard Replacement: Schritt 16, Bild 3 von 3
    • Remove the 3.5mm Phillips #00 screw securing the motherboard to the top cover.
    • Remove the 2mm Phillips #00 screw securing the motherboard to the top cover.
  17. HP Spectre 13 4003dx x360 Motherboard Replacement: Schritt 17, Bild 1 von 2 HP Spectre 13 4003dx x360 Motherboard Replacement: Schritt 17, Bild 2 von 2
    • Remove the motherboard from the alignment pins on the top cover.
Abschluss
7 weitere Nutzer:innen haben diese Anleitung absolviert.
Alie Antar
661 Reputation
2 Anleitungen geschrieben
USF Tampa, Team S5-G4, Passmore Spring 2018 Mitglied von USF Tampa, Team S5-G4, Passmore Spring 2018
USFT-PASSMORE-S18S5G4
3 Mitglieder
8 Anleitungen geschrieben
3 Kommentare
Thanks good instructions once I source a replacement board I will apply you're method. I live near Barcelona Spain any ideas on sourcing a new board??
Arthur David Mc Kee - Antwort
Thanks, it’s easy with your explications
Stéphane M - Antwort
Merci pour vos explications très détaillés qui m'ont permis de changer la carte mère d'un hp spectre x360-13 sans trop de difficultées le 13 juillet 2020.
J'ai tout particuliérement apprécié les détails pour ouvrir les différents connecteurs.
Seule difficulté était l'ouverture de la vis de fixation de la carte wifi, qui état extrêmement ferme.
Une fois la nouvelle carte mère installé le portable a démarré sans aucune autre intervention.
J'ai horreur de jetter des équipements dont seulement un élément est défectueux et je suis donc très reconnaissant de votre publication.
Un grand Merci
Albrect E.
Chantilly France
ENDRES Albrecht - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 23
Insgesamt: 9,032
