Einleitung
This guide instructs you on how to remove and replace the heatsink and fan assembly in a HP Spectre x360 13t-4000. Replacement of the heatsink may be necessary if the laptop is overheating.
Was du brauchst
Turn off and unplug the laptop.
Flip over the laptop so that the bottom backplate is exposed.
Use a T5 screwdriver to remove the six 3 mm screws that secure the backplate.
Use the same screwdriver to remove the two 7 mm screws.
Insert an opening tool under the bottom cover at the screen hinges, and gently pry the cover free.
Carefully work your way around the cover's edges to pop it off completely.
Use a Phillips #0 Screwdriver to remove the four circled 3 mm screws.
Use the same screwdriver to remove the circled 4 mm screw.
Use a Phillips #0 screwdriver to remove the last 4 mm screw under the black tape.
Unplug the cable next to the fan.
