Einleitung
This guide will teach you how to replace the Charging Ports on the HP Stream 13-c010nr.
Ersatzteile
Keine Ersatzteile angegeben.
Remove the five rubber feet from the bottom of the laptop with a plastic opening tool.
Flip the laptop over and open it up.
Wedge a plastic opening tool between the keyboard and bottom case, pry upwards to separate the two pieces.
Lift up the keyboard.
Use a spudger to flip up the retaining flaps on the keyboard ribbon cable ZIF sockets.
Pull up the ribbon cables from their sockets.
Remove the two 5mm Phillips screws from the charging port.
Remove the bracket.
Pull out the charging port.
