Zum Hauptinhalt wechseln
HP Stream 8 Speakers Replacement
Was du brauchst
  1. HP Stream 8 Speakers Replacement, Midframe: Schritt 1, Bild 1 von 1
    • Use your nail or a spudger to pry the back cover off of the device.
  2. HP Stream 8 Speakers Replacement: Schritt 2, Bild 1 von 1
    • Slide your finger around the rest of the back cover, lifting it completely off of the device.
  3. HP Stream 8 Speakers Replacement: Schritt 3, Bild 1 von 1
    • Remove ten Phillips #00 screws from the inside cover.
  4. HP Stream 8 Speakers Replacement: Schritt 4, Bild 1 von 1
    • Pry up the inside cover the same way as in the first step.
  5. HP Stream 8 Speakers Replacement, Speakers: Schritt 5, Bild 1 von 2 HP Stream 8 Speakers Replacement, Speakers: Schritt 5, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Locate the two speakers at the bottom of the device.
    • Remove the two speakers by prying them out using a pair of tweezers.
    • Detach the red and black power wiring from the device and pull the speakers entirely out of the HP Stream 8.
    • Remember where the red and black wiring is connected to the device.
    • The power wires are soldered to the device and will be difficult to detach.
  6. HP Stream 8 Speakers Replacement: Schritt 6, Bild 1 von 1
    • Grab the two replacement speakers and the soldering iron.
    • Locate where the red and black power wiring previously connected to the device.
    • Attach and re-solder the red and black power wiring.
    • For soldering help, check out iFixit's How to Solder and Desolder Connections guide.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Cal Poly, Team 34-14, Maness Spring 2016 Mitglied von Cal Poly, Team 34-14, Maness Spring 2016
CPSU-MANESS-S16S34G14
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 12
Letzte 30 Tage: 50
Insgesamt: 541
