Zum Hauptinhalt wechseln
HP Z2 Mini G3 CPU Fan Replacement
  1. HP Z2 Mini G3 CPU Fan Replacement, Access Panel: Schritt 1, Bild 1 von 1
    • Turn the device so the back-side of the device is facing you.
    • Be sure that the power is off and the A/C power cord has been disconnected before starting. Removing hardware while the power is on could damage the device or harm yourself.
    • Components of the device are subject to static damage. Work on a hard, grounded surface to prevent damage to the workstation.
  2. HP Z2 Mini G3 CPU Fan Replacement: Schritt 2, Bild 1 von 2 HP Z2 Mini G3 CPU Fan Replacement: Schritt 2, Bild 2 von 2
    • Slide and hold the latch in the direction of the engraved arrow (to the right).
  3. HP Z2 Mini G3 CPU Fan Replacement: Schritt 3, Bild 1 von 2 HP Z2 Mini G3 CPU Fan Replacement: Schritt 3, Bild 2 von 2
    • While holding the latch, lift the access panel upwards and towards yourself and set it aside upside-down.
  4. HP Z2 Mini G3 CPU Fan Replacement, CPU Fan: Schritt 4, Bild 1 von 1
    • Rotate the device so the front side is facing you (the side with the power button) and locate the CPU fan.
  5. HP Z2 Mini G3 CPU Fan Replacement: Schritt 5, Bild 1 von 1
    • Swing the fan upward, to a 90-degree angle.
  6. HP Z2 Mini G3 CPU Fan Replacement: Schritt 6, Bild 1 von 2 HP Z2 Mini G3 CPU Fan Replacement: Schritt 6, Bild 2 von 2
    • Carefully disconnect the CPU fan by pulling out the wires from the motherboard.
  7. HP Z2 Mini G3 CPU Fan Replacement: Schritt 7, Bild 1 von 1
    • Swing the fan back down and carefully unhook the CPU fan notches by pulling each tab away from the heat sink holes.
  8. HP Z2 Mini G3 CPU Fan Replacement: Schritt 8, Bild 1 von 1
    • Swing the fan up again and pull it out.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 26
Insgesamt: 1,615
