Zum Hauptinhalt wechseln
HP Z2 Mini G3 Real-Time Clock Battery Replacement
  1. HP Z2 Mini G3 Real-Time Clock Battery Replacement, Access Panel: Schritt 1, Bild 1 von 1
    • Turn the device so the back-side of the device is facing you.
    • Be sure that the power is off and the A/C power cord has been disconnected before starting. Removing hardware while the power is on could damage the device or harm yourself.
    • Components of the device are subject to static damage. Work on a hard, grounded surface to prevent damage to the workstation.
  2. HP Z2 Mini G3 Real-Time Clock Battery Replacement: Schritt 2, Bild 1 von 2 HP Z2 Mini G3 Real-Time Clock Battery Replacement: Schritt 2, Bild 2 von 2
    • Slide and hold the latch in the direction of the engraved arrow (to the right).
  3. HP Z2 Mini G3 Real-Time Clock Battery Replacement: Schritt 3, Bild 1 von 2 HP Z2 Mini G3 Real-Time Clock Battery Replacement: Schritt 3, Bild 2 von 2
    • While holding the latch, lift the access panel upwards and towards yourself and set it aside upside-down.
  4. HP Z2 Mini G3 Real-Time Clock Battery Replacement, Real-Time Clock Battery: Schritt 4, Bild 1 von 1
    • Rotate the device so the back-side is facing you and locate the RTC battery.
    • You may have to swing the CPU Fan and GPU Fan upwards to fully access the Real-Time Clock (RTC) Battery.
  5. HP Z2 Mini G3 Real-Time Clock Battery Replacement: Schritt 5, Bild 1 von 1
    • Press the battery down and away to free it of the latches.
    • Use your hand to grab and lift the battery out of the socket.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 21
Letzte 30 Tage: 124
Insgesamt: 3,175
