Zum Hauptinhalt wechseln
HTC Vive Cosmos Upper Component Cover Replacement
Was du brauchst
  1. HTC Vive Cosmos Upper Component Cover Replacement, Release the faceplate switch: Schritt 1, Bild 1 von 2 HTC Vive Cosmos Upper Component Cover Replacement, Release the faceplate switch: Schritt 1, Bild 2 von 2
    • Use your finger to push the sliding faceplate release switch, sitting to the left of the lenses, toward the bottom of the Vive.
  2. HTC Vive Cosmos Upper Component Cover Replacement, Remove the faceplate: Schritt 2, Bild 1 von 2 HTC Vive Cosmos Upper Component Cover Replacement, Remove the faceplate: Schritt 2, Bild 2 von 2
    • While holding the switch in the bottom position, pull the faceplate straight up and away from the front of the Vive.
    • Remove the faceplate.
  3. HTC Vive Cosmos Upper Component Cover Replacement, Remove the right sticker: Schritt 3, Bild 1 von 1
    • Carefully peel the right-side sticker off of the front of the Vive. If possible, keep this sticker intact and reuse it.
  4. HTC Vive Cosmos Upper Component Cover Replacement, Remove the upper component cover: Schritt 4, Bild 1 von 1
    • Use a T5 Torx driver to unscrew the screws securing the upper component cover:
    • Six 4.1 mm long screws
    • One captive screw
    • This screw is covered by a sticker. Poke your driver through the sticker to access the screw.
  5. HTC Vive Cosmos Upper Component Cover Replacement: Schritt 5, Bild 1 von 3 HTC Vive Cosmos Upper Component Cover Replacement: Schritt 5, Bild 2 von 3 HTC Vive Cosmos Upper Component Cover Replacement: Schritt 5, Bild 3 von 3
    • Angle the bottom end of the upper component cover away from the front of the Vive.
    • Pull the upper component cover away from the front of the Vive and remove it.
Abschluss
Adam O'Camb
221.513 Reputation
416 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 10
Insgesamt: 426
