Einleitung
The HTC Vive's strap and cables can loosen or fray over time. This guide will show you how to replace the Vive's straps, sound cable, and Three-in-One cable.
Werkzeuge
Keine Werkzeuge angegeben.
Slide the HTC panel covering the cables forward, away from the Vive.
Gently pull on each of the four connectors to remove the sound and Three-in-One cables.
Undo the hook and loop tape on the straps.
Slide the ends of the straps through the hinge loops.
5 weitere Nutzer haben diese Anleitung absolviert.
2 Kommentare
What is the name of the Part that holds the strap and has VIVE written on it ? Can I order that part individually ?
You can find that part, as well as the center strap holder by searching on eBay for HTC Vive headset parts. I’ve attached a link here: https://www.ebay.com/itm/Genuine-HTC-VIV...
