Einleitung
This procedure requires a moderate level of electrical wiring experience, and a few listed tools.
Was du brauchst
Schritt 1 Base Removal
Achtung: Die Schritte 1-5 stammen von einer Anleitung, die derzeit bearbeitet wird.
Hold the food processor upside down and remove the two screws indicated with a screwdriver. Once unscrewed, remove the two rubber suction pads.
Use a spudger to remove the 4 rubber base pads located at the corners of the device.
Unscrew all 4 screws that are located beneath the pads with a screwdriver and remove the plastic grey base.
Use a regular nylon spudger to remove the plastic caps at these locations with moderate pressure.
Lift and remove the plastic gears at the center of the device.
Remove any grease residue underneath the plastic gears.
Remove the remaining screws to unhinge the motor located at the center of the device using a screw driver.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
