Zum Hauptinhalt wechseln
Hand-Held Blender Motor Replacement
Was du brauchst
  1. Hand-Held Blender Motor Replacement, Motor: Schritt 1, Bild 1 von 1
    • Place the product on a clean and empty surface.
  2. Hand-Held Blender Motor Replacement: Schritt 2, Bild 1 von 1
    • Twist the attachment with the blades from the base of the blender.
  3. Hand-Held Blender Motor Replacement: Schritt 3, Bild 1 von 1
    • Unscrew the Tri-point screw (2mm) on the top to disassemble the top part of the casing.
  4. Hand-Held Blender Motor Replacement: Schritt 4, Bild 1 von 1
    • Unscrew the Phillips (2mm) connecting the middle part of the casing with the bottom part.
  5. Hand-Held Blender Motor Replacement: Schritt 5, Bild 1 von 1
    • Use force to twist the middle part from the bottom part of the casing OR use spudgers to wiggle open the product.
    • This reveals the motor.
  6. Hand-Held Blender Motor Replacement: Schritt 6, Bild 1 von 1
    • Lift the motor out of the casing.
    • Unscrew the Phillips (2mm) to disconnect the motor from the plastic part that transfers the motor rotations to the blade.
  7. Hand-Held Blender Motor Replacement: Schritt 7, Bild 1 von 1
    • With a soldering iron disconnect the wires coming from the motor from the PCB.
    • Refer to this How to Solder and Desolder Connections guide to find more information on proper soldering techniques.
Abschluss
Nina Rodenburg
109 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 23
Letzte 30 Tage: 89
Insgesamt: 3,333
