Zum Hauptinhalt wechseln
Hannspree Hannspad SN1AT71 Battery Replacement
Was du brauchst
  1. Hannspree Hannspad SN1AT71 Battery Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Place the tablet screen side up.
    • Make sure the device is turned off to avoid damage.
  2. Hannspree Hannspad SN1AT71 Battery Replacement: Schritt 2, Bild 1 von 2 Hannspree Hannspad SN1AT71 Battery Replacement: Schritt 2, Bild 2 von 2
    • Use the metal spudger to press an opening between the screen and back cover.
    • The plastic tabs are located on each corner of the back cover.
    • Be careful, as the plastic tabs are delicate.
  3. Hannspree Hannspad SN1AT71 Battery Replacement: Schritt 3, Bild 1 von 1
    • Wedge the plastic opening tool between the screen and the back panel to prevent re-engagement
  4. Hannspree Hannspad SN1AT71 Battery Replacement: Schritt 4, Bild 1 von 2 Hannspree Hannspad SN1AT71 Battery Replacement: Schritt 4, Bild 2 von 2
    • Slide the metal spudger around the casing to separate it from the inside of the tablet.
  5. Hannspree Hannspad SN1AT71 Battery Replacement: Schritt 5, Bild 1 von 2 Hannspree Hannspad SN1AT71 Battery Replacement: Schritt 5, Bild 2 von 2
    • Flip the tablet over so the screen side is down after all the tabs are separated.
    • Remove the back panel by delicately lifting it straight up.
  6. Hannspree Hannspad SN1AT71 Battery Replacement, Battery: Schritt 6, Bild 1 von 2 Hannspree Hannspad SN1AT71 Battery Replacement, Battery: Schritt 6, Bild 2 von 2
    • Remove the adhesive tape from the power connection cables.
  7. Hannspree Hannspad SN1AT71 Battery Replacement: Schritt 7, Bild 1 von 3 Hannspree Hannspad SN1AT71 Battery Replacement: Schritt 7, Bild 2 von 3 Hannspree Hannspad SN1AT71 Battery Replacement: Schritt 7, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • Instructions for desoldering can be found on the iFixit website.
    • The soldering iron is hot. It can burn you and it can cause damage to the wires and motherboard.
    • Grab hold of the red wire using the tweezers.
    • Desolder the red wire connection from the motherboard using the tip of the soldering iron.
    • Move the wire connection away from the motherboard.
    • Do not let the red wire connection touch other wires or the motherboard.
  8. Hannspree Hannspad SN1AT71 Battery Replacement: Schritt 8, Bild 1 von 3 Hannspree Hannspad SN1AT71 Battery Replacement: Schritt 8, Bild 2 von 3 Hannspree Hannspad SN1AT71 Battery Replacement: Schritt 8, Bild 3 von 3
    • Desolder the black and yellow wire connection from the motherboard by following the previous step.
    • When moving the wire connections, do not let the red wire connection touch other wires or the motherboard.
  9. Hannspree Hannspad SN1AT71 Battery Replacement: Schritt 9, Bild 1 von 3 Hannspree Hannspad SN1AT71 Battery Replacement: Schritt 9, Bild 2 von 3 Hannspree Hannspad SN1AT71 Battery Replacement: Schritt 9, Bild 3 von 3
    • Insert the flat end of the nylon spudger between the battery and the case.
    • The battery is connected to the tablet with an adhesive tape and will come free slowly.
    • Do not puncture or bend the battery while removing. If your battery is swollen, take appropriate precautions.
Abschluss
9 weitere Personen haben diese Anleitung absolviert.
Colorado Springs, Team 9-4, Panko Spring 2015 Mitglied von Colorado Springs, Team 9-4, Panko Spring 2015
UCCS-PANKO-S15S9G4
3 Mitglieder
10 Anleitungen geschrieben
3 Kommentare
Easy to follow,but, can't find a battery anywhere, so really No use
Lawrence Pearce - Antwort
Matthew,
Great job!!
I followed your instructions and no problem
Thanks
Me Eisenhut
Howard Eisenhut - Antwort
Where can I buy a replacement battery?
mwause - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 8
Letzte 30 Tage: 28
Insgesamt: 10,808
