Einleitung
This guide will show you how to remove the old front brake pads and then install new ones.
Brake pads should be changed at the owner's discretion. Most brake pads will make a squeaking or scraping noise when they are approaching the end of their life.
For the best access to the brake pads, we recommend securing the motorcycle in an upright position.
If you do not have a motorcycle lift, you will still be able change the brake pads, but it is still a good idea to secure the front wheel in place.
Using a 1/4" hex head or allen wrench, unscrew the two bolts holding the front brake assembly to the fork.
Unscrew and remove the bottom bolt, but do not completely remove the top bolt yet.
Supporting the brake assembly with one hand, remove the top bolt.
Carefully slide the brake off of the brake rotor and hang it from the metal hanger.
Using a 5/16 wrench, remove the bolt holding the stationary brake pad cover in place.
Remove the stationary brake pad cover from the brake assembly.
Being careful to not let any loose parts fall out of the brake assembly, remove the stationary brake pad from the front brake assembly.
Using a can of brake cleaner, spray out the piston and inside of the brake caliper.
Using a Phillips #2 screwdriver, remove the two screws securing the cover on the master brake-fluid reservoir.
Carefully remove the cover of the master reservoir, making sure that you do not spill any of the brake fluid.
Position the screw of a large C clamp so that the head of the screw is pressing against the inside of the brake piston.
It is possible to use your hands rather than a C clamp, but it is much more difficult.
Slowly tighten the C clamp, forcing the brake piston back into the brake cylinder until it is completely depressed.
To prevent spilling any brake fluid, first clean the area around the master cylinder with a clean rag, then replace the cover.
Inspect the new brake pads for chips or other signs of wear.
Apply a moderate amount of anti-squeal compound to the back of each new brake pad.
Using your fingers, pull the alignment peg out of its hole in the stationary caliper.
Apply a thin layer of grease to the alignment peg.
Re-install the alignment peg, but do not push it all the way in. Only push it in about half-way.
The spring should be on the same side as the alignment peg.
Place one of the brake pads into the floating caliper, with the anti-squeal side facing away from the spring and mount peg.
Holding the brake assembly in one hand and the floating caliper in the other, gently slide the floating caliper into the front brake assembly.
Move the floating caliper alignment peg so that the metal tab on the floating caliper fits together with the indentation on the alignment peg.
Being careful to not dislodge the floating caliper, insert the stationary brake pad so that the tab on the brake pad fits into the corresponding slot on the stationary caliper.
Using one hand to keep the brake pads from falling out, replace the cover on the stationary brake pad.
Insert the screw and lock washer that came with the brake pads and tighten using a Phillips #2 screwdriver.
With the piston on the outside of the rotor, carefully slide the front brake assembly back over the rotor
Slide the brake assembly until the lower hole in the brake assembly aligns with the lower mount hole on the fork.
Apply a small amount of grease on the lower brake mount screw.
Insert the screw into the lower mount hole.
Insert the upper retaining bolt into the upper bolt hole in the fork and brake assembly.
Using only your hands, tighten the bolt as much as possible.
Before taking the motorcycle up to full speed on the open road, test that the brakes work by starting and stopping at low speeds in an empty street or parking lot.
8 weitere Nutzer haben diese Anleitung absolviert.
7 Kommentare
Nice job. Was looking for a picture of that darn anti vibration clip. Thanks
The spring clip is installed wrong. The brake pad will rattle. Push the brake pad in from the rotor side with the clip pushing down hard on the pad holding it in the housing. The clip is to stop the pad from rattling in the housing, not to hold it against the piston.
GOOD JOB !!! This is almost the same exact as my 98 road king brakes.
Brett Hartt: this is so valuable for simple latin american like me. A professional tool that you are giving away. G. bless your generations forever.
