Zum Hauptinhalt wechseln
Harley-Davidson Sportster Evolution Transmission/Primary Oil Change
Was du brauchst
  1. Harley-Davidson Sportster Evolution Transmission/Primary Oil Change, Workplace Preparation: Schritt 1, Bild 1 von 2 Harley-Davidson Sportster Evolution Transmission/Primary Oil Change, Workplace Preparation: Schritt 1, Bild 2 von 2
    • For the best access to the transmission drain plug, optimal draining, and accurate re-filling, we recommend working with the bike secured in an upright position.
  2. Harley-Davidson Sportster Evolution Transmission/Primary Oil Change, Removing the Primary Chain Inspection Cover: Schritt 2, Bild 1 von 3 Harley-Davidson Sportster Evolution Transmission/Primary Oil Change, Removing the Primary Chain Inspection Cover: Schritt 2, Bild 2 von 3 Harley-Davidson Sportster Evolution Transmission/Primary Oil Change, Removing the Primary Chain Inspection Cover: Schritt 2, Bild 3 von 3
    • Using a 5/32 Hex or Allen screwdriver, unscrew the two screws from the primary chain inspection cover.
    • Your inspection cover may not be round, depending on the year. However, it will be in the same location and secured by similar screws.
    • Remove the primary chain inspection cover from the transmission housing.
  3. Harley-Davidson Sportster Evolution Transmission/Primary Oil Change, Draining the Transmission Oil: Schritt 3, Bild 1 von 3 Harley-Davidson Sportster Evolution Transmission/Primary Oil Change, Draining the Transmission Oil: Schritt 3, Bild 2 von 3 Harley-Davidson Sportster Evolution Transmission/Primary Oil Change, Draining the Transmission Oil: Schritt 3, Bild 3 von 3
    • The transmission drain plug is located on the underside of the transmission on the left side of the bike, near the kickstand bumper.
    • Place a drain pan underneath the drain plug.
    • Using a wrench, unscrew the transmission drain plug and remove it.
    • Your drain plug may be 5/8" or 3/4" depending on the year.
    • Allow all the oil to drain out of the transmission. It should take about five minutes.
  4. Harley-Davidson Sportster Evolution Transmission/Primary Oil Change: Schritt 4, Bild 1 von 2 Harley-Davidson Sportster Evolution Transmission/Primary Oil Change: Schritt 4, Bild 2 von 2
    • While the oil is draining from the transmission, clean the transmission drain plug.
    • Using a spare rag or paper towel, clean the drain plug, removing excess oil and metal shavings.
    • There is a magnet on the end of the drain plug to capture any ferrous metal residue.
  5. Harley-Davidson Sportster Evolution Transmission/Primary Oil Change, Removing the Clutch Inspection Cover: Schritt 5, Bild 1 von 2 Harley-Davidson Sportster Evolution Transmission/Primary Oil Change, Removing the Clutch Inspection Cover: Schritt 5, Bild 2 von 2
    • Using a T27 screwdriver bit, remove the four screws holding the clutch inspection cover in place.
  6. Harley-Davidson Sportster Evolution Transmission/Primary Oil Change: Schritt 6, Bild 1 von 2 Harley-Davidson Sportster Evolution Transmission/Primary Oil Change: Schritt 6, Bild 2 von 2
    • Insert a heavy duty spudger or similar prying tool into the gap between the clutch inspection cover and the transmission housing near where clutch cable enters the housing.
    • Gently pry the clutch inspection cover away from the transmission housing.
    • The clutch cover spring may fall out. Be sure to keep track of this and re-install it before replacing the clutch inspection cover.
  7. Harley-Davidson Sportster Evolution Transmission/Primary Oil Change, Installing the Transmission Drain Plug: Schritt 7, Bild 1 von 2 Harley-Davidson Sportster Evolution Transmission/Primary Oil Change, Installing the Transmission Drain Plug: Schritt 7, Bild 2 von 2
    • Re-insert the transmission drain plug into the transmission housing and hand tighten.
    • Using a 3/4" wrench, tighten down the transmission drain plug.
    • It is important to not over-tighten the drain plug. Tightening the plug too much can strip the threads on the aluminum housing. The plug should be tight, but not too tight. The correct torque specification is 14 - 21 ft-lbs (168 - 252 in-lbs).
  8. Harley-Davidson Sportster Evolution Transmission/Primary Oil Change, Adding New Oil: Schritt 8, Bild 1 von 2 Harley-Davidson Sportster Evolution Transmission/Primary Oil Change, Adding New Oil: Schritt 8, Bild 2 von 2
    • Insert the nozzle of a funnel into the primary chain inspection hole.
    • Pouring slowly, pour approximately 1 qt of oil into the transmission.
    • As you pour, watch the clutch inspection hole. Make sure that the oil level stays below the edge of the clutch inspection hole.
    • This may require less than the entire quart of oil.
  9. Harley-Davidson Sportster Evolution Transmission/Primary Oil Change, Re-assembly: Schritt 9, Bild 1 von 3 Harley-Davidson Sportster Evolution Transmission/Primary Oil Change, Re-assembly: Schritt 9, Bild 2 von 3 Harley-Davidson Sportster Evolution Transmission/Primary Oil Change, Re-assembly: Schritt 9, Bild 3 von 3
    • Before re-installing the primary chain inspection cover, make sure the rubber O-ring on the inside of the primary chain inspection hole is clean and properly seated.
    • Also make sure that the rubber o-rings are clean and in proper condition before replacing the screws in the primary chain inspection cover.
    • Using a 5/32" Hex or Allen screw head, re-install the primary chain inspection cover.
  10. Harley-Davidson Sportster Evolution Transmission/Primary Oil Change: Schritt 10, Bild 1 von 2 Harley-Davidson Sportster Evolution Transmission/Primary Oil Change: Schritt 10, Bild 2 von 2
    • Using a T27 Screwdriver head, reinstall the clutch inspection cover. Install the screws in the following order:
    • Top
    • Bottom
    • Left
    • Right
    • Once all of the screws have been lightly hand-tightened, use a torque wrench to tighten them to their proper specification of 7 - 12 ft-lbs (84 - 108 in-lbs). Tighten the screws in the same order as before.
Ziellinie
80 weitere Nutzer:innen haben diese Anleitung absolviert.
Brett Hartt
127.941 Reputation
143 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
136 Mitglieder
17.298 Anleitungen geschrieben
32 Kommentare
but you CANT use gear oil for cluthc!!!
car motor oil CANT be used for bike cluthc!!! Motorcycle motoroil CAN!
Maicol - Antwort
Is synthetic 20w50 ok to use?
Jordan -
What the !&&* is a cluthc?
redin575 -
You can use Amsoil 20w50 Synthetic V-Twin Motorcycle Oil. It is certified for engine, transmission, and primary chaincase lubricant. Manuals will specify gear oil as well (75w90), which is also appropriate to use. Note as Eric Essen wrote that these oils are defined differently. Link to the Amsoil 20w50: https://www.amsoil.com/p/20w-50-syntheti...
Sir_Nerd -
I change my my transmission oil exactly how it showed and yes the spring with the nut on the end came off and I put it right back. Now I have no tension at all in my clutch basically I have no clutch anymore. This is the first time I've taken the inspection plate off during a transmission fluid change. I usually drain it and automatically just put one quart in. What could I have done wrong?
Argyle - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 92
Letzte 7 Tage: 678
Letzte 30 Tage: 3,113
Insgesamt: 496,050
