Zum Hauptinhalt wechseln
Hasbro Iron Man Infinity Nano Gauntlet Speaker Replacement
Was du brauchst
  1. Hasbro Iron Man Infinity Nano Gauntlet Speaker Replacement, Speaker: Schritt 1, Bild 1 von 1
    • Find the location of the damaged speaker. The speaker can be located above the battery pack on the forearm.
    • Find the damaged wire. It must be replaced with a new one.
  2. Hasbro Iron Man Infinity Nano Gauntlet Speaker Replacement: Schritt 2, Bild 1 von 2 Hasbro Iron Man Infinity Nano Gauntlet Speaker Replacement: Schritt 2, Bild 2 von 2
    • Desolder the damaged wire from the speaker and replace it with a new one.
    • It will be beneficial to use the wire stripping tool in order to do this.
  3. Hasbro Iron Man Infinity Nano Gauntlet Speaker Replacement: Schritt 3, Bild 1 von 1
    • Once the new wire is attached to the speaker, it must then be reattached to the circuit board.
    • Once the new wires are securely placed in the correct spot, the hand can be put back together.
Abschluss
Tori Mariano
347 Reputation
1 Anleitung geschrieben
Marist, Team 1-3, Chaterdon Spring 2023 Mitglied von Marist, Team 1-3, Chaterdon Spring 2023
MARS-CHATERDON-S23S1G3
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 5
Insgesamt: 60
