Einleitung
Use this guide to replace the speaker in the Hasbro Iron Man Infinity Nano Gauntlet. This speaker is needed in order to display the sounds that come out of the hand, such as snapping and pop sounds. The speaker will need to be replaced if the hand is constantly used, thus resulting in inadequate, muffled, or no sound at all.
A wire stripper may be beneficial to use in this process.
Ensure that the hand is off before proceeding.
Was du brauchst
Find the location of the damaged speaker. The speaker can be located above the battery pack on the forearm.
Find the damaged wire. It must be replaced with a new one.
Once the new wire is attached to the speaker, it must then be reattached to the circuit board.
Once the new wires are securely placed in the correct spot, the hand can be put back together.
