Zum Hauptinhalt wechseln
Hisense Sero 8 Motherboard Replacement
Was du brauchst
  1. Hisense Sero 8 Motherboard Replacement, Motherboard: Schritt 1, Bild 1 von 3 Hisense Sero 8 Motherboard Replacement, Motherboard: Schritt 1, Bild 2 von 3 Hisense Sero 8 Motherboard Replacement, Motherboard: Schritt 1, Bild 3 von 3
    • Remove the back cover of the device using the plastic opening tool.
    • Pry open a corner of the device, then continue down the side with the tool to open the device.
  2. Hisense Sero 8 Motherboard Replacement: Schritt 2, Bild 1 von 2 Hisense Sero 8 Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Remove the black tape located to the left of the device.
    • Remove the clear tape directly below the camera.
  3. Hisense Sero 8 Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Remove the seven 4.43mm screws located at the top of the device using the Phillips #00 screwdriver.
    • There is no need to remove the bottom two screws holding the speakers in place.
  4. Hisense Sero 8 Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Unlock the three ribbon cable connector latches to remove the cables.
  5. Hisense Sero 8 Motherboard Replacement: Schritt 5, Bild 1 von 3 Hisense Sero 8 Motherboard Replacement: Schritt 5, Bild 2 von 3 Hisense Sero 8 Motherboard Replacement: Schritt 5, Bild 3 von 3
    • Be cautious of the extremely hot tip of the soldering iron.
    • Desolder the red, black, and yellow wires to remove the motherboard. Take a look at this guide to learn how to solder and desolder connections.
    • Desolder the black wire located on the top left of the device.
    • Once desoldered, carefully lift the motherboard out of the device.
Abschluss
Katharina
506 Reputation
2 Anleitungen geschrieben
USF Tampa, Team 1-2, Leahy Winter 2015 Mitglied von USF Tampa, Team 1-2, Leahy Winter 2015
USFT-LEAHY-W15S1G2
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 10
Insgesamt: 1,335
