Einleitung
After extended use, the motherboard may become defunct and the device may require a new one. Follow this guide to remove and replace the motherboard of your Hisense Sero 8.
Was du brauchst
Remove the back cover of the device using the plastic opening tool.
Pry open a corner of the device, then continue down the side with the tool to open the device.
Remove the black tape located to the left of the device.
Remove the clear tape directly below the camera.
Remove the seven 4.43mm screws located at the top of the device using the Phillips #00 screwdriver.
Desolder the red, black, and yellow wires to remove the motherboard. Take a look at this guide to learn how to solder and desolder connections.
Desolder the black wire located on the top left of the device.
Once desoldered, carefully lift the motherboard out of the device.
