Zum Hauptinhalt wechseln
Honda Fit Reset Oil Life Indicator Replacement
Was du brauchst
    • Turn the key in the ignition to the run position (right before the start position)
    • Press the SELECT/RESET knob repeatedly until the engine oil life indicator is displayed.
    • Press and hold the SELECT/RESET knob for more than 10 seconds. The engine oil life indicator and the maintenance code(s) will blink.
    • Press and hold the SELECT/RESET knob for more than 5 seconds. The maintenance items code(s) will disappear, and the engine oil life will reset to 100%.
    • Turn the key in the ignition to the off position, and then start the engine to verify the indicator has been reset.
Abschluss
You did it!
19 weitere Nutzer:innen haben diese Anleitung absolviert.
Jasen Friedle
3.821 Reputation
3 Anleitungen geschrieben
5 Kommentare
Great. I did it—and I’m a girl!!
pthompso99 - Antwort
Excellent! Glad to hear it.
Jasen Friedle - Antwort
in my case i followed the step through. 100% oil life was achieved but when i turn the ignition off and turn it back on to verify, it goes back to 15%
Esosa Aghimien - Antwort
And how can I start the car that it won't start
sbukataake - Antwort
Have you tried changing your blinker fluid?
neegnorg -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 22
Letzte 7 Tage: 125
Letzte 30 Tage: 507
Insgesamt: 75,159
