Einleitung
Prerequisite only! This guide shows how to remove or replace the wheels on a Honda FRC800K1A Rear Tine Tiller.
You will need to support the tiller during this process. Use jack stands, large pieces of wood, or other strong supports. Rock the tiller back and forth on its supports before beginning to ensure that it won’t fall or tip over during repairs.
Was du brauchst
Firmly grip the base of the connector and pull it away from the spark plug to disconnect it.
Use needle nose pliers to remove the cotter pin from the wheel lock pin.
Remove the wheel lock pin.
