Zum Hauptinhalt wechseln
Honeywell HY-204 Rotation Motor Replacement
Was du brauchst
  1. Honeywell HY-204 Rotation Motor Replacement, Rotation Motor: Schritt 1, Bild 1 von 1
    • Before you begin, be sure to unplug the fan.
    • Lay fan on the ground and use your fingers peel the three feet off the bottom of the fan.
  2. Honeywell HY-204 Rotation Motor Replacement: Schritt 2, Bild 1 von 1
    • Remove the three 12mm screws using the Phillips #0 Screwdriver.
  3. Honeywell HY-204 Rotation Motor Replacement: Schritt 3, Bild 1 von 2 Honeywell HY-204 Rotation Motor Replacement: Schritt 3, Bild 2 von 2
    • Remove the two 10mm screws using the Phillips #0 Screwdriver.
  4. Honeywell HY-204 Rotation Motor Replacement: Schritt 4, Bild 1 von 1
    • Move the rotation motor left and right to reveal the screw connecting it to the fan.
    • Remove the 18mm screw from the side of the motor using the Phillips #0 Screwdriver.
  5. Honeywell HY-204 Rotation Motor Replacement: Schritt 5, Bild 1 von 1
    • Using the wire cutters, severe the wires connecting the rotation motor to the fan.
    • To put back together you will need to resolder or use wire connectors to reattach motor.
Abschluss
Cal Poly, Team 10-40, Amido Fall 2014 Mitglied von Cal Poly, Team 10-40, Amido Fall 2014
CPSU-AMIDO-F14S10G40
3 Mitglieder
7 Anleitungen geschrieben
2 Kommentare
It seems that these instructions are on “How to eeplacr the oscillation motor". But they neglect the requirement to have a replacement motor or how/where to get the replacement motor. Otherwise the steps seem clear.
Alan A. Kopta - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 10
Insgesamt: 2,739
