Einleitung
If your Hoover Power Path Deluxe FH50951 isn’t cleaning well or the brush roll isn’t spinning, the belt may need replacing. The belt powers the brush roll, which is key for effective carpet cleaning. This simple fix is similar to replacing the brush roll and can restore your vacuum’s performance. You should compare the old belt to the new one to ensure they match in size and type. Using the wrong belt can affect performance.
Was du brauchst
Remove the four 18.6 mm screws labeled 1-4 using a Phillips #1 screwdriver.
Remove the piece that was being held down by those screws.
Remove the four 18.6 mm screws with arrows listing 5-8 using a Phillips #1 screwdriver.
Remove the wheel assembly on the left side of the vacuum.
Lift up the belt to give enough slack to allow the brush roll to come out.
While lifting the belt, pull/push upward away from the cleaner to pop it out.
Gently slide the belt off of the motor shaft and lift it out of the vacuum.
