Zum Hauptinhalt wechseln
Hoover Power Path Deluxe FH50951 Belt Replacement
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
Hoover Power Path Deluxe FH50951 Belt Replacement: Schritt 0, Bild 1 von 2 Hoover Power Path Deluxe FH50951 Belt Replacement: Schritt 0, Bild 2 von 2
  • Gently slide the belt off of the motor shaft and lift it out of the vacuum.
  • Loop one end of the new belt around the motor shaft, making sure it sits securely in the groove.
  • Ensure the belt is securely placed in the correct slot on both the motor shaft and the brush roll. A loosely installed or improperly positioned belt can slip, break, or prevent the brush roll from spinning correctly, potentially damaging your vacuum. Double-check that the belt is aligned and tensioned properly before reassembling the vacuum.
Hier Übersetzung einfügen
