Zum Hauptinhalt wechseln
Hover-1 Charger Battery Replacement
Was du brauchst
  1. Hover-1 Charger Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Hover-1 Charger Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Flip the hoverboard over so that the warning label is facing up.
    • Remove the twelve 12 mm screws with a Phillips #2 screwdriver.
    • Remove the four 10 mm screws with a Phillips #2 screwdriver.
    • The screws nearest to the wheels may be hard to access. Be sure to use a long, thin screwdriver.
  2. Hover-1 Charger Battery Replacement: Schritt 2, Bild 1 von 1
    • Pull the right cover away from the hoverboard to expose the battery.
  3. Hover-1 Charger Battery Replacement: Schritt 3, Bild 1 von 2 Hover-1 Charger Battery Replacement: Schritt 3, Bild 2 von 2
    • Unplug the battery by disconnecting the two pronged black and yellow cable.
  4. Hover-1 Charger Battery Replacement: Schritt 4, Bild 1 von 1
    • Pull the left cover away from the hoverboard.
  5. Hover-1 Charger Battery Replacement: Schritt 5, Bild 1 von 2 Hover-1 Charger Battery Replacement: Schritt 5, Bild 2 von 2
    • Disconnect the two pronged black and yellow cable.
    • Thread the cable through the middle cylinder of the hoverboard.
  6. Hover-1 Charger Battery Replacement: Schritt 6, Bild 1 von 2 Hover-1 Charger Battery Replacement: Schritt 6, Bild 2 von 2
    • Unscrew the four 10mm screws that are holding the battery casing in place. Use a Phillips #2 screwdriver.
    • If there is a zip-tie connecting the wires together, carefully cut it with a wire cutters.
  7. Hover-1 Charger Battery Replacement: Schritt 7, Bild 1 von 3 Hover-1 Charger Battery Replacement: Schritt 7, Bild 2 von 3 Hover-1 Charger Battery Replacement: Schritt 7, Bild 3 von 3
    • On the battery side, unplug the white five pin connector on the circuitboard.
    • Unplug the black, yellow, green and red connector on the circuitboard.
  8. Hover-1 Charger Battery Replacement: Schritt 8, Bild 1 von 1
    • Move all the loose cables to the side. Pull the battery casing away from the battery.
  9. Hover-1 Charger Battery Replacement: Schritt 9, Bild 1 von 1
    • Use the opening tool to remove the battery from the metal casing.
    • The battery is stuck to the metal casing with strong adhesive; do not be afraid to apply a strong force with the opening tool.
  10. Hover-1 Charger Battery Replacement: Schritt 10, Bild 1 von 1
    • Remove the battery.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team S12-G1, Regan Fall 2019 Mitglied von Cal Poly, Team S12-G1, Regan Fall 2019
CPSU-REGAN-F19S12G1
4 Mitglieder
6 Anleitungen geschrieben
Ein Kommentar
Can I replace my battery 25.2v to a 36v.
Airie Green - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 16
Letzte 7 Tage: 48
Letzte 30 Tage: 214
Insgesamt: 7,037
