Zum Hauptinhalt wechseln
Hover-1 Charger Bluetooth Speaker Replacement
Was du brauchst
  1. Hover-1 Charger Bluetooth Speaker Replacement, Unplugging the Battery: Schritt 1, Bild 1 von 2 Hover-1 Charger Bluetooth Speaker Replacement, Unplugging the Battery: Schritt 1, Bild 2 von 2
    • Flip the hoverboard over so that the warning label is facing up.
    • Remove the twelve 12 mm screws with a Phillips #2 screwdriver.
    • Remove the four 10 mm screws with a Phillips #2 screwdriver.
    • The screws nearest to the wheels may be hard to access. Be sure to use a long, thin screwdriver.
  2. Hover-1 Charger Bluetooth Speaker Replacement: Schritt 2, Bild 1 von 1
    • Pull the right cover away from the hoverboard to expose the battery.
  3. Hover-1 Charger Bluetooth Speaker Replacement: Schritt 3, Bild 1 von 2 Hover-1 Charger Bluetooth Speaker Replacement: Schritt 3, Bild 2 von 2
    • Disconnect the two pronged black and yellow cable.
  4. Hover-1 Charger Bluetooth Speaker Replacement: Schritt 4, Bild 1 von 1
    • Pull the left cover away from the hoverboard.
  5. Hover-1 Charger Bluetooth Speaker Replacement: Schritt 5, Bild 1 von 2 Hover-1 Charger Bluetooth Speaker Replacement: Schritt 5, Bild 2 von 2
    • Disconnect the two pronged black and yellow cable. The battery is now fully disconnected.
  6. Hover-1 Charger Bluetooth Speaker Replacement, Bluetooth Speaker: Schritt 6, Bild 1 von 1
    • Locate the speaker attached to the left cover of the hoverboard.
  7. Hover-1 Charger Bluetooth Speaker Replacement: Schritt 7, Bild 1 von 2 Hover-1 Charger Bluetooth Speaker Replacement: Schritt 7, Bild 2 von 2
    • Unplug the red and white four pin connector from the circuit board. Unplugging this connector is photographed as an example.
    • Unplug the white and blue three pin connector from the circuit board.
    • Unplug the white and blue two pin connector from the circuit board.
  8. Hover-1 Charger Bluetooth Speaker Replacement: Schritt 8, Bild 1 von 2 Hover-1 Charger Bluetooth Speaker Replacement: Schritt 8, Bild 2 von 2
    • Using a Phillips #1 screwdriver, remove the two 7 mm screws from the circuit board.
  9. Hover-1 Charger Bluetooth Speaker Replacement: Schritt 9, Bild 1 von 2 Hover-1 Charger Bluetooth Speaker Replacement: Schritt 9, Bild 2 von 2
    • Using a Phillips #1 screwdriver, remove the three screws securing the speaker to the outer shell.
  10. Hover-1 Charger Bluetooth Speaker Replacement: Schritt 10, Bild 1 von 1
    • Remove the speaker and circuit board from the outer shell.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Cal Poly, Team S12-G1, Regan Fall 2019 Mitglied von Cal Poly, Team S12-G1, Regan Fall 2019
CPSU-REGAN-F19S12G1
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 17
Insgesamt: 1,290
