Zum Hauptinhalt wechseln
Hover-1 Coast Controller Battery Replacement
Was du brauchst
  1. Hover-1 Coast Controller Battery Replacement, Controller Battery: Schritt 1, Bild 1 von 3 Hover-1 Coast Controller Battery Replacement, Controller Battery: Schritt 1, Bild 2 von 3 Hover-1 Coast Controller Battery Replacement, Controller Battery: Schritt 1, Bild 3 von 3
    • Identify the three screws and using a Phillips #1 screwdriver loosen the the screws.
    • Remove the three screws.
  2. Hover-1 Coast Controller Battery Replacement: Schritt 2, Bild 1 von 3 Hover-1 Coast Controller Battery Replacement: Schritt 2, Bild 2 von 3 Hover-1 Coast Controller Battery Replacement: Schritt 2, Bild 3 von 3
    • Pull the backside of the controller off.
    • The inside of the controller should look like this.
    • The marked area is the battery.
  3. Hover-1 Coast Controller Battery Replacement: Schritt 3, Bild 1 von 1
    • Remove the black foam piece covering the battery.
  4. Hover-1 Coast Controller Battery Replacement: Schritt 4, Bild 1 von 2 Hover-1 Coast Controller Battery Replacement: Schritt 4, Bild 2 von 2
    • Desolder the battery connections from the motherboard.
  5. Hover-1 Coast Controller Battery Replacement: Schritt 5, Bild 1 von 2 Hover-1 Coast Controller Battery Replacement: Schritt 5, Bild 2 von 2
    • Using a plastic opening tool, pry the battery off the motherboard.
Abschluss
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 438
