Einleitung
This guide will walk you through how to replace a faulty or worn-down back wheel on a Hover-1 Eagle scooter. You should replace your back wheel if your back wheel has been worn down or damaged. To determine if you need to replace your back wheel, refer to our Troubleshooting Guide.
Was du brauchst
Use a Phillips #2 screwdriver to remove the 2mm screw located underneath the reflective sticker.
Repeat Steps 1-3 for the other side.
Apply pressure to the axle using a hex bit 5.0 to push it slightly out on the other side.
Take hold of the 6 mm axle screw on the opposite side and remove the axle by pulling firmly towards you.
To reassemble your device, repeat Steps 1-4 in reverse order.
4 weitere Personen haben diese Anleitung absolviert.
