Einleitung
This guide will walk you through how to replace a faulty or wobbly kickstand on a Hover-1 Eagle scooter. You should replace your kickstand if your kickstand is defective, wobbly, or not the proper length. To determine if you need to replace your kickstand, refer to our Troubleshooting Guide.
Was du brauchst
Remove the two 6mm axle screws using a hex bit 4.0.
Remove the kickstand from the scooter.
Eine weitere Person hat diese Anleitung absolviert.
