Einleitung
This guide will walk you through how to replace a faulty or non-functional LED headlight on a Hover-1 Eagle scooter. You should replace your headlight if your headlight no longer turns on or appears cracked or damaged. To determine if you need to replace your headlight, refer to our Troubleshooting Guide.
Was du brauchst
Remove the four screws from the bottom side of the display housing using a Phillips #2 screwdriver.
Using a soldering iron, desolder the black and red wires from the LED circuit board.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
