Einleitung
This guide will walk you through how to replace a faulty or non-functional throttle or brake lever on a Hover-1 Eagle scooter. You should replace your throttle or brake lever if your lever fails to accelerate or stop the scooter or appears damaged. To determine if you need to replace your throttle or brake lever, refer to our Troubleshooting Guide.
Was du brauchst
Push back the fastening clips by wedging the plastic spudger between the clip and the throttle handle.
Insert iFixit opening picks between each fastening clip and the throttle handle to prevent re-fastening.
Pull the throttle lever off gently by pulling towards you.
Apply pressure to the throttle handle until you hear the fastening clips take hold the of the throttle lever.
4 weitere Personen haben diese Anleitung absolviert.
24 Kommentare
Great detail……….. Where can I buy the replacement part (throttle) the company hover1 isn't answering me and they don't have this part on their website. Thanks
Im needed a throttle did anyone have any luck?
Where do I buy the part where do I get it please let me know The brake lever
Necesito acelerador y no lo encuentro.
I cant squeeze the spudger and the pick between this and the spudger broke…what the!!!
