Zum Hauptinhalt wechseln
Hover-1 XLS Ignition Replacement
Was du brauchst
  1. Hover-1 XLS Ignition Replacement, Ignition: Schritt 1, Bild 1 von 1
    • Remove the six 16mm #3 Hex head screws located on the front panel.
    • The screws are held in with Teflon tape, so use a chemical remover like B'laster to loosen the screws.
  2. Hover-1 XLS Ignition Replacement: Schritt 2, Bild 1 von 3 Hover-1 XLS Ignition Replacement: Schritt 2, Bild 2 von 3 Hover-1 XLS Ignition Replacement: Schritt 2, Bild 3 von 3
    • Grab the front panel and gently lift it up to the side.
    • The front panel is connected to the ignition, so don't pull too hard or the wires will get damaged.
  3. Hover-1 XLS Ignition Replacement: Schritt 3, Bild 1 von 1
    • Remove the two, 19 mm Phillips #2 screws holding the ignition.
    • Remove the yellow and red wires that are connected to the ignition. To remove them, look at the soldering guide provided by iFixit.
Abschluss
Cal Poly, Team S1-G2, White Winter 2019 Mitglied von Cal Poly, Team S1-G2, White Winter 2019
CPSU-WHITE-W19S1G2
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 11
Letzte 30 Tage: 35
Insgesamt: 1,085
