Einleitung
The LCD Screen displays the status of the bike and is a clear indicator if your bike is on or off. Before beginning this replacement, you should know that it is a prerequisite to get to the ignition off. To get to the ignition, follow the ignition guide. You should also be able to solder. If you don't know how to solder, just follow the soldering guide in iFixit.
Was du brauchst
Remove the four 10mm Phillips #2 screws holding the casing of the LCD.
Remove the casing on the LCD.
Remove the four 10mm Phillips #2 screws holding the LCD onto the bike.
Gently lift off the LCD screen.
