Zum Hauptinhalt wechseln
How To Fix A Leaky Faucet
Was du brauchst
  1. How To Fix A Leaky Faucet, Cartridge Faucet: Schritt 1, Bild 1 von 2 How To Fix A Leaky Faucet, Cartridge Faucet: Schritt 1, Bild 2 von 2
    • Shut off the hot and cold water valves underneath the sink by twisting them clockwise until they are tight.
    • The appearance of these valves will differ from sink to sink, but most operate the same.
    • To test that the water has been completely shut off, try turning on the faucet like you would normally. If no water comes out, you're in luck!
    • When reopening the valves after the repair, leave the faucet in its on position. This will prevent pressurized air from building up in the faucet cartridge.
  2. How To Fix A Leaky Faucet: Schritt 2, Bild 1 von 3 How To Fix A Leaky Faucet: Schritt 2, Bild 2 von 3 How To Fix A Leaky Faucet: Schritt 2, Bild 3 von 3
    • Pull up on the the pop-up drain stopper to seal the sink drain.
    • Place a towel in the sink to catch any excess water or faucet hardware.
  3. How To Fix A Leaky Faucet: Schritt 3, Bild 1 von 3 How To Fix A Leaky Faucet: Schritt 3, Bild 2 von 3 How To Fix A Leaky Faucet: Schritt 3, Bild 3 von 3
    • Use your fingers or a prying tool to remove the plug button from the top of the faucet handle.
  4. How To Fix A Leaky Faucet: Schritt 4, Bild 1 von 1
    • Use a screwdriver to remove the single handle screw.
    • The number and head type/length of the screws may vary from faucet to faucet.
  5. How To Fix A Leaky Faucet: Schritt 5, Bild 1 von 3 How To Fix A Leaky Faucet: Schritt 5, Bild 2 von 3 How To Fix A Leaky Faucet: Schritt 5, Bild 3 von 3
    • Gently pull the faucet handle up from the rest of the faucet.
  6. How To Fix A Leaky Faucet: Schritt 6, Bild 1 von 2 How To Fix A Leaky Faucet: Schritt 6, Bild 2 von 2
    • Remove the temperature limit stop from the top of the cartridge.
    • When removing the temperature limit stop and indexer, take note of their position. The limit stop and indexer determine the maximum temperature that water can reach when coming out of the faucet.
    • Even if you mark the position of the indexer and stop, you may still need to reset the temperature limit after addressing the leak. Follow the instructions for your specific faucet if they are available.
  7. How To Fix A Leaky Faucet: Schritt 7, Bild 1 von 3 How To Fix A Leaky Faucet: Schritt 7, Bild 2 von 3 How To Fix A Leaky Faucet: Schritt 7, Bild 3 von 3
    • Unscrew the bonnet from the faucet.
  8. How To Fix A Leaky Faucet: Schritt 8, Bild 1 von 2 How To Fix A Leaky Faucet: Schritt 8, Bild 2 von 2
    • Remove the temperature limit indexer from the top of the cartridge.
  9. How To Fix A Leaky Faucet: Schritt 9, Bild 1 von 2 How To Fix A Leaky Faucet: Schritt 9, Bild 2 von 2
    • Use an adjustable wrench to loosen the bonnet nut.
  10. How To Fix A Leaky Faucet: Schritt 10, Bild 1 von 2 How To Fix A Leaky Faucet: Schritt 10, Bild 2 von 2
    • Remove the bonnet nut.
  11. How To Fix A Leaky Faucet: Schritt 11, Bild 1 von 2 How To Fix A Leaky Faucet: Schritt 11, Bild 2 von 2
    • Remove the cartridge.
  12. How To Fix A Leaky Faucet: Schritt 12, Bild 1 von 3 How To Fix A Leaky Faucet: Schritt 12, Bild 2 von 3 How To Fix A Leaky Faucet: Schritt 12, Bild 3 von 3
    • Remove the cartridge o-rings.
    • If the leak has been coming only from the end of the faucet, replace the cartridge.
    • If the faucet has been leaking from the base or from the faucet handle, replace the o-rings.
    • When installing new o-rings, be sure to properly seat them into the grooves on the underside of the cartridge. A misaligned o-ring can easily cause a new leak.
  13. How To Fix A Leaky Faucet: Schritt 13, Bild 1 von 2 How To Fix A Leaky Faucet: Schritt 13, Bild 2 von 2
    • When reinserting the cartridge, be sure that the keys on the cartridge line up with the keys on the base of the faucet.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
Geoff Wacker
92.511 Reputation
89 Anleitungen geschrieben
1 Kommentar zur Anleitung
I am looking for the brand of the faucet in this picture. We have one faucet and need aerator for it but no brand on it...?
Kittie Finch - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 10
Letzte 7 Tage: 97
Letzte 30 Tage: 301
Insgesamt: 7,356
