Einleitung
This guide will walk you through removing, cleaning, lubricating, and reassembling an older model coaster brake.
Loosen the nuts holding the axle in place using the two wrenches.
Unscrew the brake arm from the frame of the bicycle using the screwdriver.
Loosen the nuts holding the axle in the wheel using the wrenches. Unscrew the axle, and remove the bearings and brake assembly. Set them off to the side on a rag.
Clean all of the internal parts in the tub using the toothbrush.
Be sure to get all of the areas where the bearings will sit (see red circles)
Also scrub the threads on the sprocket (see orange line)
Dry the parts using a paper towel.
When dry, set them off to the side on a rag.
Reassemble the parts of the bearing and axle assembly which go on the opposite side of the hub from the sprocket. This includes the brake pads and the cone
Using your fingers, make sure the bearings are well coated with grease.
Make sure to add some grease at key points shown (red lines).
Gently screw the sprocket into the hub.
Screw the bearing race on. Make sure not to tighten too much. The sprocket and wheel should still spin easily.
Replace the wheel onto the bicycle.
Tighten the nuts to hold the wheel in place.
Before continuing, spin the wheel and crank the pedals to make sure everything spins smoothly. If not, check to make sure the axle nuts aren't too tight.
Congratulations! You've finished cleaning your coaster brake. Test-ride the bicycle. Listen to make sure that there are no grinding noises. Be sure to test the brake several times. When you're done, make sure all the nuts are still tight.
4 weitere Nutzer haben diese Anleitung absolviert.
Ein Kommentar
I have Huffy coaster bike 26”, i’m trying to change the rear tire bearing but I don’t know the size of it. the outside ones are 3/16 X9, but I need to know the size of the small inner one at the gear it was 7 balls.
