Zum Hauptinhalt wechseln
How to Calibrate an Optical Fingerprint Sensor for Your Motorola Phone
Was du brauchst
  1. How to Calibrate an Optical Fingerprint Sensor for Your Motorola Phone, Enter the CQATest menu: Schritt 1, Bild 1 von 2 How to Calibrate an Optical Fingerprint Sensor for Your Motorola Phone, Enter the CQATest menu: Schritt 1, Bild 2 von 2
    • Open the phone app.
    • Open the dial screen.
    • Enter *#*#2486#*#* on the dial pad.
    • If the CQATest menu doesn't come up immediately, press "Call".
  2. How to Calibrate an Optical Fingerprint Sensor for Your Motorola Phone, Select the CQA menu mode: Schritt 2, Bild 1 von 1
    • If any pop-ups appear, allow them.
    • Select "CQA Menu Mode" from the options.
  3. How to Calibrate an Optical Fingerprint Sensor for Your Motorola Phone, Select the sensor option: Schritt 3, Bild 1 von 1
    • Select "Sensor" from the options.
  4. How to Calibrate an Optical Fingerprint Sensor for Your Motorola Phone, Select Fingerprint Egis FOD SMTP: Schritt 4, Bild 1 von 1
    • Select "Fingerprint Egis Fod SMTP" from the options.
  5. How to Calibrate an Optical Fingerprint Sensor for Your Motorola Phone: Schritt 5, Bild 1 von 3 How to Calibrate an Optical Fingerprint Sensor for Your Motorola Phone: Schritt 5, Bild 2 von 3 How to Calibrate an Optical Fingerprint Sensor for Your Motorola Phone: Schritt 5, Bild 3 von 3
    • Press "START" on the top left corner of the screen.
    • You should see a menu that says "Normal Scan: ok, click NEXT" with a list of tests under it.
    • If any of the tests failed, restart from the beginning of this guide.
    • Press "NEXT" on the top right corner.
    • Wait until the message at the top of the screen changes to "Put FLESH FLAT, click NEXT".
  6. How to Calibrate an Optical Fingerprint Sensor for Your Motorola Phone, Apply the indented pink box: Schritt 6, Bild 1 von 3 How to Calibrate an Optical Fingerprint Sensor for Your Motorola Phone, Apply the indented pink box: Schritt 6, Bild 2 von 3 How to Calibrate an Optical Fingerprint Sensor for Your Motorola Phone, Apply the indented pink box: Schritt 6, Bild 3 von 3
    • For the next two steps, make sure you're using the pink box that has a small square indented in it and not the pink box that has grooves.
    • With the indented side facing down, place the pink box over the red box on the bottom of the screen.
    • Make sure the pink box covers the red box as much as possible. Deviations could result in a "Fail" result or an inaccurate calibration.
  7. How to Calibrate an Optical Fingerprint Sensor for Your Motorola Phone: Schritt 7, Bild 1 von 2 How to Calibrate an Optical Fingerprint Sensor for Your Motorola Phone: Schritt 7, Bild 2 von 2
    • Press down on the pink box with your thumb.
    • While pressing down on the box, use your other hand to select "NEXT" on the top right of the phone.
    • Continue pressing down on the box until the message at the top of the screen changes to "Put BLACK FLAT, click NEXT".
  8. How to Calibrate an Optical Fingerprint Sensor for Your Motorola Phone, Apply the black box: Schritt 8, Bild 1 von 3 How to Calibrate an Optical Fingerprint Sensor for Your Motorola Phone, Apply the black box: Schritt 8, Bild 2 von 3 How to Calibrate an Optical Fingerprint Sensor for Your Motorola Phone, Apply the black box: Schritt 8, Bild 3 von 3
    • With the indented side facing down, place the black box over the red box on the bottom of the screen.
    • Make sure the black box covers the red box as much as possible. Deviations could result in a "Fail" result or an inaccurate calibration.
  9. How to Calibrate an Optical Fingerprint Sensor for Your Motorola Phone: Schritt 9, Bild 1 von 2 How to Calibrate an Optical Fingerprint Sensor for Your Motorola Phone: Schritt 9, Bild 2 von 2
    • Press down on the black box with your thumb.
    • Continue pressing down on the box until the message at the top of the screen changes to "Put FLESH CHART, click NEXT".
  10. How to Calibrate an Optical Fingerprint Sensor for Your Motorola Phone, Apply the grooved pink box: Schritt 10, Bild 1 von 3 How to Calibrate an Optical Fingerprint Sensor for Your Motorola Phone, Apply the grooved pink box: Schritt 10, Bild 2 von 3 How to Calibrate an Optical Fingerprint Sensor for Your Motorola Phone, Apply the grooved pink box: Schritt 10, Bild 3 von 3
    • For the next two steps, make sure you're using the pink box that has grooves and not the pink box that has a small square indented in it.
    • With the grooved side down and the grooves vertical, place the pink box over the red box on the bottom of the screen.
  11. How to Calibrate an Optical Fingerprint Sensor for Your Motorola Phone: Schritt 11, Bild 1 von 2 How to Calibrate an Optical Fingerprint Sensor for Your Motorola Phone: Schritt 11, Bild 2 von 2
    • Continue pressing down on the box until you get a message about the calibration results.
  12. How to Calibrate an Optical Fingerprint Sensor for Your Motorola Phone: Schritt 12, Bild 1 von 2 How to Calibrate an Optical Fingerprint Sensor for Your Motorola Phone: Schritt 12, Bild 2 von 2
    • You will see "Calibration test: ok" if the calibration was successful.
    • If you see "Calibration test: fail" at the top of the screen, restart from the beginning of this guide.
Abschluss
Your optical fingerprint sensor is calibrated and ready for use.
If the calibration fails for any reason, repeat the calibration procedure.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Spencer Day
55.203 Reputation
408 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
136 Mitglieder
17.430 Anleitungen geschrieben
Ein Kommentar
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 70
Letzte 30 Tage: 385
Insgesamt: 4,895
