Zum Hauptinhalt wechseln
How to Cover Up Ceiling Water Stains
Was du brauchst
  1. How to Cover Up Ceiling Water Stains, How to Cover Up Ceiling Water Stains: Schritt 1, Bild 1 von 1
    • Cover the area around the water stains with plastic sheets and tape.
  2. How to Cover Up Ceiling Water Stains: Schritt 2, Bild 1 von 2 How to Cover Up Ceiling Water Stains: Schritt 2, Bild 2 von 2
    • Wet a wipe with any bleach that you have in hand.
    • Clean the water-stained area with a bleach wipe.
    • This is an optional step.
  3. How to Cover Up Ceiling Water Stains: Schritt 3, Bild 1 von 2 How to Cover Up Ceiling Water Stains: Schritt 3, Bild 2 von 2
    • Apply the stain sealer to the area that was cleaned with wipes.
    • Be careful; this can stain anything.
  4. How to Cover Up Ceiling Water Stains: Schritt 4, Bild 1 von 1
    • Once the stain sealer is applied, wait for it to dry.
  5. How to Cover Up Ceiling Water Stains: Schritt 5, Bild 1 von 1
    • When the area is dry, remove the plastic.
Abschluss
To cover up your water stains at home, follow this easy guide.
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 13
Letzte 30 Tage: 36
Insgesamt: 518
