Zum Hauptinhalt wechseln
How to Drain and Clean the Drain Filter on the LG WM3170CW
Was du brauchst
  1. How to Drain and Clean the Drain Filter on the LG WM3170CW, How to Drain and Clean the Drain Filter on the LG WM3170CW: Schritt 1, Bild 1 von 1
    • Turn off the washing machine.
  2. How to Drain and Clean the Drain Filter on the LG WM3170CW: Schritt 2, Bild 1 von 3 How to Drain and Clean the Drain Filter on the LG WM3170CW: Schritt 2, Bild 2 von 3 How to Drain and Clean the Drain Filter on the LG WM3170CW: Schritt 2, Bild 3 von 3
    • Open the panel that is located at the bottom left of the washing machine.
  3. How to Drain and Clean the Drain Filter on the LG WM3170CW: Schritt 3, Bild 1 von 2 How to Drain and Clean the Drain Filter on the LG WM3170CW: Schritt 3, Bild 2 von 2
    • Unlatch the draining tube and prepare the shallow tub for draining
    • Do not pull on the tube farther than it can go. This can damage the tube.
    • Unscrew the plug and drain the water into the tub.
    • Once no more water is coming out, plug the tube and place it back in its original position.
  4. How to Drain and Clean the Drain Filter on the LG WM3170CW: Schritt 4, Bild 1 von 2 How to Drain and Clean the Drain Filter on the LG WM3170CW: Schritt 4, Bild 2 von 2
    • Unscrew the filter counterclockwise and remove it.
    • Dump out the components in the filter and properly dispose of it.
  5. How to Drain and Clean the Drain Filter on the LG WM3170CW: Schritt 5, Bild 1 von 1
    • Using a toothbrush or damp washcloth, gently clean the inside and outside of the filter to remove leftover debris.
  6. How to Drain and Clean the Drain Filter on the LG WM3170CW: Schritt 6, Bild 1 von 2 How to Drain and Clean the Drain Filter on the LG WM3170CW: Schritt 6, Bild 2 von 2
    • Screw the filter clockwise back into place.
    • Ensure the drain and filter are returned into their original positions and close the panel.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
3 Kommentare zur Anleitung
Como resolver o problema decorrente do código TE?
José Cláudio Carlos Dos Santos - Antwort Teilen
I pulled the hose too far and unconnected. How to connect it back?
Michelle Bonacim - Antwort Teilen
Drain hose has come out of the drain conector…
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 25
Letzte 30 Tage: 105
Insgesamt: 10,847
