Zum Hauptinhalt wechseln
How to Fix Stuck Yamaha PSR-6 Keyboard Keys
Was du brauchst
  1. How to Fix Stuck Yamaha PSR-6 Keyboard Keys, How to Fix Stuck Yamaha PSR-6 Keyboard Keys: Schritt 1, Bild 1 von 3 How to Fix Stuck Yamaha PSR-6 Keyboard Keys, How to Fix Stuck Yamaha PSR-6 Keyboard Keys: Schritt 1, Bild 2 von 3 How to Fix Stuck Yamaha PSR-6 Keyboard Keys, How to Fix Stuck Yamaha PSR-6 Keyboard Keys: Schritt 1, Bild 3 von 3
    • Turn around the keyboard with the keys facing down.
    • Remove the 15 10 mm screws using a Phillips #1 screwdriver.
    • Remove the five 12 mm screws using a Phillips #1 screwdriver.
    • Remove the extra two 10 mm screws in the bottom using a Phillips #1 screwdriver.
    Frag FixBot
    Kommentar hinzufügen
  2. How to Fix Stuck Yamaha PSR-6 Keyboard Keys: Schritt 2, Bild 1 von 1
    • Pull the tab and remove the battery cover.
    Frag FixBot
  3. How to Fix Stuck Yamaha PSR-6 Keyboard Keys: Schritt 3, Bild 1 von 1
    • Take the back plate of the piano with both hands and remove it.
    Frag FixBot
  4. How to Fix Stuck Yamaha PSR-6 Keyboard Keys: Schritt 4, Bild 1 von 2 How to Fix Stuck Yamaha PSR-6 Keyboard Keys: Schritt 4, Bild 2 von 2
    • Turn around the piano with the tiles facing up.
    • Remove the speaker's cover on the left side of the keyboard.
    • Remove the plastic cover on the right side of the keyboard.
    Frag FixBot
  5. How to Fix Stuck Yamaha PSR-6 Keyboard Keys: Schritt 5, Bild 1 von 2 How to Fix Stuck Yamaha PSR-6 Keyboard Keys: Schritt 5, Bild 2 von 2
    • Flip the keyboard with the keys facing down.
    • Remove the single 12 mm screw using a Phillips #1 screwdriver.
    Frag FixBot
  6. How to Fix Stuck Yamaha PSR-6 Keyboard Keys: Schritt 6, Bild 1 von 1
    • Lift the front plate of the keyboard and rotate it 180°.
    • While doing this, grab the speaker with the other hand so it doesn't fall and hit the table.
    Frag FixBot
  7. How to Fix Stuck Yamaha PSR-6 Keyboard Keys: Schritt 7, Bild 1 von 2 How to Fix Stuck Yamaha PSR-6 Keyboard Keys: Schritt 7, Bild 2 von 2
    • Remove all the 10 mm screws on the top of the keys using a Phillips #1 screwdriver.
    Frag FixBot
  8. How to Fix Stuck Yamaha PSR-6 Keyboard Keys: Schritt 8, Bild 1 von 1
    • Use a spudger to separate the teeth to the plates that hold the keys together.
    • Do this gently as the plate may be fragile.
    Frag FixBot
  9. How to Fix Stuck Yamaha PSR-6 Keyboard Keys: Schritt 9, Bild 1 von 1
    • Pull the black plate that holds the keys together horizontally away from the keys.
    • With the top of the keys exposed, use a damp cloth or wipes to clean the space between the tiles.
    Frag FixBot
Abschluss
5 weitere Personen haben diese Anleitung absolviert.
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 20
Letzte 30 Tage: 81
Insgesamt: 2,965
