Einleitung
The soldered connections in the average XLR cable can break under heavy use. Use this guide to disassemble an XLR connector and resolder the broken connection.
Was du brauchst
Place the end of the XLR Cable on a clean, uncluttered surface.
Using a small screwdriver, unscrew the single screw near the top of the cable.
Gently pull apart the exterior metal from the internal mechanism.
Assess which connections have fallen loose. In this instance, the white cable is disconnected.
Assess whether or not there's enough exposed wire to reconnect loose cables. In this instance, the exposed cables are too short to effectively reconnect.
If the exposed wires are too short, use wire strippers or a razor to cut back the insulation.
Separate the wires.
When the soldering is complete, reconnect the metal exterior to the head of the cable.
Using a small screwdriver, reattach the single screw.
4 weitere Personen haben diese Anleitung absolviert.
1 Kommentar zur Anleitung
Great repair. If the cabke is broken I have a video on resolving that issue. https://youtu.be/E8CiX4cnc-U
