Zum Hauptinhalt wechseln
How to Fix a Stuck Button in Sharp Calculator
Was du brauchst
  1. How to Fix a Stuck Button in Sharp Calculator, Button Keys: Schritt 1, Bild 1 von 1
    • Turn the power off by pressing a button named 2NDF located in the top-left corner.
    • Press the button named ON/C in the top-right corner.
  2. How to Fix a Stuck Button in Sharp Calculator: Schritt 2, Bild 1 von 2 How to Fix a Stuck Button in Sharp Calculator: Schritt 2, Bild 2 von 2
    • Flip the calculator over so that the back panel is facing upwards.
    • Remove two 5mm Phillips #0 screws from the battery cover by turning the screwdriver in a counter-clockwise direction.
    • Remove the remaining four 5mm Phillips #0 screws from the back panel cover.
  3. How to Fix a Stuck Button in Sharp Calculator: Schritt 3, Bild 1 von 1
    • Remove the battery cover.
    • Insert a spudger into the slot located in the top-right corner and pry the battery out.
  4. How to Fix a Stuck Button in Sharp Calculator: Schritt 4, Bild 1 von 1
    • Remove the front panel by sticking an opening tool into a small gap between front and back panel.
    • Push the tool down with force and pry open the right side carefully.
    • Detach the front panel from the back panel by lifting the front board.
    • Separate the front and back panel slowly to avoid damaging the LCD ribbon.
  5. How to Fix a Stuck Button in Sharp Calculator: Schritt 5, Bild 1 von 1
    • Use a Phillips #0 screwdriver to remove the eight 5mm screws from the motherboard.
  6. How to Fix a Stuck Button in Sharp Calculator: Schritt 6, Bild 1 von 2 How to Fix a Stuck Button in Sharp Calculator: Schritt 6, Bild 2 von 2
    • Lift the motherboard by holding both sides and placing it on the top panel.
    • Lift the grey padding upwards by holding any corner and place it on top of the motherboard.
    • Press the grey padding and put pressure downward to avoid sticking from physical buttons.
  7. How to Fix a Stuck Button in Sharp Calculator: Schritt 7, Bild 1 von 2 How to Fix a Stuck Button in Sharp Calculator: Schritt 7, Bild 2 von 2
    • Use a spudger to flip, remove, and adjust the position of buttons.
    • Ensure the placement of buttons is correct. Use STEP 1 Image as a reference to the location of buttons.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Angehängte Dokumente
York University, Team S1-G5, O'Regan Summer 2020 Mitglied von York University, Team S1-G5, O'Regan Summer 2020
YORK-O'REGAN-SU20S1G5
1 Mitglied
1 Anleitung geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 11
Letzte 30 Tage: 33
Insgesamt: 5,423
