Einleitung
Follow this general guide to learn how to install an M.2 SSD in your laptop.
Before you work on your laptop, be sure to completely power off and unplug it. Make sure the laptop is not in standby, sleep, or hibernation mode.
Was du brauchst
Use a screwdriver to remove the preinstalled standoff.
Find the correct standoff location that corresponds to your desired M.2 SSD form factor.
Screw in the standoff.
Grip the SSD on the sides near the screw indent.
Gently slide the SSD into the socket at about a 30˚ angle.
Use your finger to hold the SSD down horizontally, making sure that the screw indent aligns with the standoff.
Screw down the SSD to secure it.
Use tweezers or your fingers to place a thermal pad on the top of the SSD.
Installation didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
6 weitere Nutzer:innen haben diese Anleitung absolviert.
