Zum Hauptinhalt wechseln
How to Reattach a Broken Table Leg
Was du brauchst
  1. How to Reattach a Broken Table Leg, How to Reattach a Broken Table Leg: Schritt 1, Bild 1 von 1
    • Carefully place the table on an even surface and identify the broken parts.
  2. How to Reattach a Broken Table Leg: Schritt 2, Bild 1 von 1
    • Carefully place the table with the tabletop face down on a clean cloth or plastic cover to prevent scratching.
    • You might need some assistance depending on the size of the table.
  3. How to Reattach a Broken Table Leg: Schritt 3, Bild 1 von 2 How to Reattach a Broken Table Leg: Schritt 3, Bild 2 von 2
    • Remove the screws from the broken leg.
    • I am using a Mastercraft flathead 3 mm screwdriver in this step. Your screwdriver type will depend on the screw. Follow this guide to learn more about screwdriver types.
    • Remove the broken leg.
    • Use a paper towel to clean the surface of the table and legs.
  4. How to Reattach a Broken Table Leg: Schritt 4, Bild 1 von 2 How to Reattach a Broken Table Leg: Schritt 4, Bild 2 von 2
    • Caution: If you have sensitive skin, avoid direct contact with the glue and use gloves before performing this step.
    • Caution: Use adequate ventilation or wear a mask to prevent inhaling the glue fumes.
    • Carefully apply the glue on the part that connects the table and legs.
  5. How to Reattach a Broken Table Leg: Schritt 5, Bild 1 von 1
    • Press the leg against the glue for few minutes.
    • Allow the glue to dry for at least 10 minutes.
  6. How to Reattach a Broken Table Leg: Schritt 6, Bild 1 von 1
    • Once the glue is dry, insert the screws.
  7. How to Reattach a Broken Table Leg: Schritt 7, Bild 1 von 3 How to Reattach a Broken Table Leg: Schritt 7, Bild 2 von 3 How to Reattach a Broken Table Leg: Schritt 7, Bild 3 von 3
    • Use an electric drill or a screwdriver to tighten the screws.
  8. How to Reattach a Broken Table Leg: Schritt 8, Bild 1 von 1
    • Use a paper towel to remove extra glue stains.
    • Allow the table to dry for 24 hours before turning the table.
  9. How to Reattach a Broken Table Leg: Schritt 9, Bild 1 von 2 How to Reattach a Broken Table Leg: Schritt 9, Bild 2 von 2
    • After 24 hours, carefully return the table to the original position.
    • Depending on the size of the table, you might need some assistance to turn the table.
Abschluss
Repeat these steps to fix any other broken legs on the table.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
York University, Team S1-G15, Woodhouse Winter 2021 Mitglied von York University, Team S1-G15, Woodhouse Winter 2021
YORK-WOODHOUSE-W21S1G15
1 Mitglied
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 47
Letzte 30 Tage: 217
Insgesamt: 9,606
