Zum Hauptinhalt wechseln
How to Repair a Sole Delamination From the Midsole
Was du brauchst
  1. How to Repair a Sole Delamination From the Midsole, Check the damaged area: Schritt 1, Bild 1 von 2 How to Repair a Sole Delamination From the Midsole, Check the damaged area: Schritt 1, Bild 2 von 2
    • Identify the part of the midsole that needs to be repaired.
  2. How to Repair a Sole Delamination From the Midsole, Remove glue residue: Schritt 2, Bild 1 von 2 How to Repair a Sole Delamination From the Midsole, Remove glue residue: Schritt 2, Bild 2 von 2
    • Use a rough piece of sandpaper to rub-off the remaining glue residue and to roughen the surface for enhanced glue adhesion.
    • Be careful not to damage the material below the midsole.
  3. How to Repair a Sole Delamination From the Midsole, Prepare the Shoe Glue: Schritt 3, Bild 1 von 3 How to Repair a Sole Delamination From the Midsole, Prepare the Shoe Glue: Schritt 3, Bild 2 von 3 How to Repair a Sole Delamination From the Midsole, Prepare the Shoe Glue: Schritt 3, Bild 3 von 3
    • Apply the glue to both the sole and the separated part.
    • Apply pressure using clamps.
    • Note: Follow the instructions of the glue used to know the exact drying time. In this example we left the product to dry overnight.
  4. How to Repair a Sole Delamination From the Midsole, Finished and ready!: Schritt 4, Bild 1 von 1
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
Abschluss
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
Ben Blischke
5.208 Reputation
49 Anleitungen geschrieben
INTERSPORT Mitglied von INTERSPORT
Community
17 Mitglieder
61 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 6
Insgesamt: 59
