Zum Hauptinhalt wechseln
How to Repair an Upper Delamination
Was du brauchst
  1. How to Repair an Upper Delamination, Check the damaged area: Schritt 1, Bild 1 von 3 How to Repair an Upper Delamination, Check the damaged area: Schritt 1, Bild 2 von 3 How to Repair an Upper Delamination, Check the damaged area: Schritt 1, Bild 3 von 3
    • Identify the upper part that needs to be repaired
    • For better pressing later, remove the insole.
  2. How to Repair an Upper Delamination, Remove glue residue: Schritt 2, Bild 1 von 3 How to Repair an Upper Delamination, Remove glue residue: Schritt 2, Bild 2 von 3 How to Repair an Upper Delamination, Remove glue residue: Schritt 2, Bild 3 von 3
    • Use a rough piece of sandpaper to rub-off the remaining glue residue and to roughen the surface for enhanced glue adhesion.
    • Be careful not to damage the material above the glued sole edge.
  3. How to Repair an Upper Delamination, Prepare the glue: Schritt 3, Bild 1 von 3 How to Repair an Upper Delamination, Prepare the glue: Schritt 3, Bild 2 von 3 How to Repair an Upper Delamination, Prepare the glue: Schritt 3, Bild 3 von 3
    • Follow the instructions of the 2-component glue.
    • Push-out both components of the glue into a small tray and mix the mass until it is equally merged.
  4. How to Repair an Upper Delamination, Coat upper and sole with glue: Schritt 4, Bild 1 von 3 How to Repair an Upper Delamination, Coat upper and sole with glue: Schritt 4, Bild 2 von 3 How to Repair an Upper Delamination, Coat upper and sole with glue: Schritt 4, Bild 3 von 3
    • Using a small spatula, coat the prepared upper surface with the glue.
    • Note: We recommend to get support by another person to pull apart the sole from the upper.
    • Spread the glue equally onto the roughened area and the inside of the sole edge.
  5. How to Repair an Upper Delamination, Pressing both parts together: Schritt 5, Bild 1 von 3 How to Repair an Upper Delamination, Pressing both parts together: Schritt 5, Bild 2 von 3 How to Repair an Upper Delamination, Pressing both parts together: Schritt 5, Bild 3 von 3
    • Let the glue dry while putting one hand into the shoe and grasping the sole with the other one.
    • Note: Follow the instructions of the glue used to know the exact drying time. In this example we held the parts together for 3 minutes and then let it dry for 24 hours.
  6. How to Repair an Upper Delamination, Finished and ready!: Schritt 6, Bild 1 von 3 How to Repair an Upper Delamination, Finished and ready!: Schritt 6, Bild 2 von 3 How to Repair an Upper Delamination, Finished and ready!: Schritt 6, Bild 3 von 3
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
Abschluss
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
Ben Blischke
5.208 Reputation
48 Anleitungen geschrieben
INTERSPORT Mitglied von INTERSPORT
Community
17 Mitglieder
60 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 43
