Zum Hauptinhalt wechseln
How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.
Was du brauchst
  1. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower., How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: Schritt 1, Bild 1 von 1
    • Start with a flat, open space to work.
  2. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: Schritt 2, Bild 1 von 2 How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: Schritt 2, Bild 2 von 2
    • Unscrew these three 1.2 mm screws.
  3. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: Schritt 3, Bild 1 von 1
    • Remove the Bubble Sprocket from the motor.
  4. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: Schritt 4, Bild 1 von 1
    • Unscrew these four 1.2mm screws holding the plate on.
  5. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: Schritt 5, Bild 1 von 1
    • Remove the plate.
  6. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: Schritt 6, Bild 1 von 1
    • Connect the red wire to the top right pin.
  7. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: Schritt 7, Bild 1 von 1
    • Solder the Red wire to the metal pin.
    • (Warning Soldering is very hot!)
  8. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: Schritt 8, Bild 1 von 2 How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: Schritt 8, Bild 2 von 2
    • Connect the yellow wire to the bottom right pin.
    • Solder the yellow wire to the bottom right pin.
    • (Warning Soldering iron is very hot!)
  9. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: Schritt 9, Bild 1 von 1
    • Replace the plate over the wires.
  10. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: Schritt 10, Bild 1 von 1
    • Put four 1.2 mm screws for the plate back into place.
  11. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: Schritt 11, Bild 1 von 1
    • Put three 1.2mm screws for the motor back into place.
  12. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: Schritt 12, Bild 1 von 1
    • Insert the Bubble sprocket onto the motor.
  13. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: Schritt 13, Bild 1 von 1
    • You are now finished!
Ziellinie
John Hiller
110 Reputation
1 Anleitung geschrieben
Colorado Springs, Team 7-5, Mcmichael Fall 2015 Mitglied von Colorado Springs, Team 7-5, Mcmichael Fall 2015
UCCS-MCMICHAEL-F15S7G5
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 22
Insgesamt: 1,820
