Einleitung
Using this guide you can fix this toy in 15-20 minutes without having to buy a new one. There are several tools you will need to fix this Little Tikes Bubble Mower. You will need a Philips screw driver size PH1, and a soldering tool. (If you don't know how to solder, look at iFixit's How to Solder and Desolder connections.)
Was du brauchst
Start with a flat, open space to work.
Connect the yellow wire to the bottom right pin.
Solder the yellow wire to the bottom right pin.
Fast fertig!
Ziellinie
