Zum Hauptinhalt wechseln
How to Replace the Screen Adhesive on Your Switch Lite
Was du brauchst
    1. How to Replace the Screen Adhesive on Your Switch Lite, Apply isopropyl alcohol: Schritt 1, Bild 1 von 3 How to Replace the Screen Adhesive on Your Switch Lite, Apply isopropyl alcohol: Schritt 1, Bild 2 von 3 How to Replace the Screen Adhesive on Your Switch Lite, Apply isopropyl alcohol: Schritt 1, Bild 3 von 3
      • Apply high concentration (90% or greater) isopropyl alcohol to the old screen adhesive on the frame.
      • Wait one minute to allow the alcohol to penetrate the adhesive.
      Frag FixBot
      Kommentar hinzufügen
    2. How to Replace the Screen Adhesive on Your Switch Lite, Remove the old adhesive: Schritt 2, Bild 1 von 3 How to Replace the Screen Adhesive on Your Switch Lite, Remove the old adhesive: Schritt 2, Bild 2 von 3 How to Replace the Screen Adhesive on Your Switch Lite, Remove the old adhesive: Schritt 2, Bild 3 von 3
      In diesem Schritt verwendetes Werkzeug:
      Microfiber Cleaning Cloths
      $3.99
      • Use the flat end of a spudger to scrape all the old adhesive from the frame.
      • Use a microfiber cloth to clean the frame.
      Frag FixBot
    3. How to Replace the Screen Adhesive on Your Switch Lite, Measure and cut the adhesive: Schritt 3, Bild 1 von 3 How to Replace the Screen Adhesive on Your Switch Lite, Measure and cut the adhesive: Schritt 3, Bild 2 von 3 How to Replace the Screen Adhesive on Your Switch Lite, Measure and cut the adhesive: Schritt 3, Bild 3 von 3
      Tesa 61395 Tape
      $8.95
      • Measure and cut four strips of 2 mm‑wide Tesa tape for the back of the screen:
      • Two strips for the long edges
      • Two strips for the short edges
      • You can use other adhesives, but make sure the strips are no wider than 3 mm.
      Frag FixBot
    4. How to Replace the Screen Adhesive on Your Switch Lite, Apply the adhesive: Schritt 4, Bild 1 von 3 How to Replace the Screen Adhesive on Your Switch Lite, Apply the adhesive: Schritt 4, Bild 2 von 3 How to Replace the Screen Adhesive on Your Switch Lite, Apply the adhesive: Schritt 4, Bild 3 von 3
      • Apply the adhesive strips sticky side down to the back of the screen, making sure the tape goes under the screen and digitizer cables.
      Frag FixBot
    5. How to Replace the Screen Adhesive on Your Switch Lite: Schritt 5, Bild 1 von 2 How to Replace the Screen Adhesive on Your Switch Lite: Schritt 5, Bild 2 von 2
      • Use tweezers to remove the liners from the adhesive strips.
      Frag FixBot
    6. How to Replace the Screen Adhesive on Your Switch Lite, Orient the screen: Schritt 6, Bild 1 von 1
      • Orient the screen before adhering it to the frame:
      • The right edge of the screen has two wide cables that line up with the action buttons.
      • The left edge of the screen has one small cable that lines up with the directional pad.
      Frag FixBot
    7. How to Replace the Screen Adhesive on Your Switch Lite, Place the screen on the frame: Schritt 7, Bild 1 von 2 How to Replace the Screen Adhesive on Your Switch Lite, Place the screen on the frame: Schritt 7, Bild 2 von 2
      • Lay the right edge of the screen on the frame at a downward angle, making sure its cables go under the frame.
      Frag FixBot
    8. How to Replace the Screen Adhesive on Your Switch Lite: Schritt 8, Bild 1 von 2 How to Replace the Screen Adhesive on Your Switch Lite: Schritt 8, Bild 2 von 2
      • Lay the left edge of the screen onto the frame, making sure the small cable goes under the frame.
      Frag FixBot
    9. How to Replace the Screen Adhesive on Your Switch Lite, Secure the new screen: Schritt 9, Bild 1 von 2 How to Replace the Screen Adhesive on Your Switch Lite, Secure the new screen: Schritt 9, Bild 2 von 2
      • Press down firmly around the perimeter of the screen to adhere it to the frame.
      • Make sure the top of the screen is flush with the frame.
      Frag FixBot
Ziellinie
11 weitere Personen haben diese Anleitung absolviert.
Spencer Day
199.149 Reputation
1.243 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
123 Mitglieder
63.854 Anleitungen geschrieben
1 Kommentar zur Anleitung
When reassessing the ifixit screen there’s a blue “film.” On the back of the screen inside the device on the new screen, should I take that off?
Noah Brown - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 80
Letzte 30 Tage: 374
Insgesamt: 14,219
